Question about Nintendo DS Lite Console
Ds lite fireline
Ds game card has a open fat error
SOURCE:
SOURCE: DS Lite unable to read DS game card
try to use rubbing alcohol on a qtip and clean the game connectors and inside the game slot. Or try to blow on it. that usually does the trick
Posted on Aug 24, 2007
xedcom
  • 127 Answers
SOURCE: multi game card for ds lite
Thanks for giving the card name, that helps to investigate possible causes of your problem.
The common causes of these problems are full cards memory because the seller fill the memory with game roms to make the device sell more attractive, though to save games you need memory and completelly filling the memory capacity of these cards make them to have issues like the ones you told before.
The good thing is that you can connect the NDSL to your PC throught the suplied USB cable and SLOT-2 (GBA game slot) N-Card Flash Linker cartridge.
You can download the required software latest files from the manufacturers website. Once connected, turn on your DS, your PC will recognize it and you will be able to drag and drop files, then you can delete or copy some less used game roms or save files from the card to your PC leaving free space for the others to run.
If nothing of that works for you, then you would try to find a FAQ or support forum site where you can find more options to solve this issue.
Good Luck...
Posted on Oct 17, 2007
  • 10 Answers
SOURCE: my ds lite will not read any games
You may have a bent pin on the game slot. Try inserting a game several times rapidly in and out. Look at your game cartridges and see if one of the contacts is damaged in the same place on all of the cartridges.
If this does not solve the issue, you will need to get your console repaired. Either the repair shop will replace all of the electronics or resolder a new game slot on your existing board.
Posted on May 26, 2008
Jack Dye
  • 268 Answers
SOURCE: DS Lite - Game card recognition
there is an error with the ds itself, you will have to get it sent off for repairs or find a nearby gaming repair shop
Posted on Jun 29, 2008
  • 60 Answers
SOURCE: how to put games in my memory card at Nintendo DS Lite?
To get an in depth answer seach you tube but in brief.
You will need to download the system files for your type of R4 or flash card you are using, make sure you get the exact model type as they are not interchangeable.
Drag and drop the files to your card you will see either 4 or 5 files. Then make a folder called Games on your micro SD card and load your games into that folder.
It quite involved but the tutorials on you tube go right into it.
Posted on Jul 11, 2009
Hi, I have a Nintendo DS Lite. I am using the same game card for the past 1 year. But, since yesterday, I get the error message "open fat error" after switching on the DS. Please suggest a...
Sounds like the card is corrupt, back up all your saves/game files,. and format the card, put back the firmware/saves/games and see if it works.
Mar 02, 2011 | Nintendo DS Lite Console
Sram check error on Ncard
you have the wrong card, go to the store again and take the DS and ask them for the correct card.
Hope this is helpful
Oct 13, 2008 | Nintendo DS Lite Console
Ds fireline wont load up
its probably the wrong ds or its broken
Dec 31, 2009 | Nintendo DSi Black Console
Can't play ds fireline (100 games in 1) in dsi
The DSi blocks all flashcards that were released before it. Your card is one of those blocked cards, so you can't do much except return that and buy a DSi-compatible cart online. As for the region, the DSi hasn't been hacked yet so region changing isn't possible at the moment.
Jun 10, 2009 | Nintendo DSi Black Console
When i put ds fire card in the ds the screen says error FAT cluster size must 16 k byte please reformat card can you help
is it a DS lite, or DSi, and does it have the ram card in the advance slot if it is a ds or ds lite? if not you will need one
May 05, 2009 | Nintendo DS Lite Console
Wont read ds card
i think your ds card needs reformatting, or not actually the card but the micro sd, back up all the games and reformat, if stuck let me know.
Apr 10, 2009 | Nintendo DS Lite Console
N-card error
Depending on what type of card you have, you need to go to the appropriate website and download the latest software files.If the card takes a memory card you may also find formatting the card with the fat 32 system more reliable and this may get rid of the Open fat error also.
Hope this helps
Aug 03, 2008 | Nintendo DS Lite Console
Ds " Error: Open Fat Error!
if you want,
i do fire card repairs well all types of super cards for the ds and i havnt failed once, here i have the software to repaire it if you are interested, any questions email me
jackdye@yahoo.co.uk
Jul 13, 2008 | Nintendo DS Lite Console
Fat 32 error
If its possible can you get a new multi game card? If not if the warranty is still good take it back for a new ds, or you could always send it in but it takes 2-3 weeks for repairs.
Jan 31, 2008 | Nintendo DS Lite Console
Open fat error in game card pack
I am not sure about that 88 in 1 game card pack you talk about but that sounds like a flash card cartridge for NDS. If you just would give me more information about that game card like seller store or website or device serial/model, slot used and flash type used. I will investigate about it.
The first: make sure the flash card is well plugged into the cartridge and plug it out and in again to be sure. Better if you clean the flash memory contacts with a cloth or q-tip.
Second: find the cartridge documentation and try to find a web page. Usually all the product issues like this are placed in the FAQs area of the manufacturer site. Or at least with the name you can find information in any related forum.
Third: If like I think, a fat error can happen when you use a flash memory card with a fat partition different or not supported by the cartridge hardware or firmware. That is not something that can happen just by using it unlike the files get corrupted. And you always have the option toformat the card, reload the cartridge software, upgrade the firmware, download new game roms, convert them if nescesary and load them in the flash card to play. Usually these devices use FAT16 or FAT file format (not FAT32 until you know this device support that format).
This is all i can say by now with the information you gave me...
Good Luck...
Oct 12, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
