Home | GE | GSS20IEP Side by Side Refrigerator | Refrigerator not coo...
GE GSS20IEP Side by Side Refrigerator
Problem for GE GSS20IEP Side by Side Refrigerator
Refrigerator not cooling enough and freezer has ice on back wall
By jordantim on Jun 28, 2009
I have a GE side by side fridge (GSS22GPE). There was ice build up on the back of freezer and the cooling was not good in the top of freezer and the refrigerator. I defrosted it manually and cleaned out the condensor and it worked for about 3 weeks. Then the ice started to form again and I am back to square one. What are the defrosting parts that could go bad and is there a way to check to find out which component is bad. Is it easy to fix and worth it. The refrigerator is 5 or 6 years old. I have some experience with refrigeration but not refrigerators. I work for a compressed air drying company.
Best Solution
posted on Jun 28, 2009
Very Helpful)
Maytag317
Rank: Guru  GE Expert
Rating: 93%, 648 votes
HI, You will need to remove the rear inside panel of the freezer and check the defrost heater located on the bottom of the evaporator coils, for continuity. If the heater shows a break in it, replace the heater. If the heater checks out ok, check the bimetal switch that is located on the top of the evaporator coil. It has to be tested while it is cold. Check coninuity and if is shows the switch is open, replace the bi-metal switch.
If the heater and bi-metal check out ok, you will need to replace the mother board.
The heater is the nost common issue with this model.
I hope this helps you and if I can assist you further, please let me know.
Vic
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for GE GSS20IEP Side by Side
Questions and Unsolved Problems for GE GSS20IEP Side by Side
Do you recommend GE GSS20IEP Side by Side Refrigerator?
Answer
Answer
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay... (More)
Answer
My ice dispenser keeps freezing up and clogging. It appears the flapper that closes after ice is... (More)
Answer
the fridge and freezer are not working.. the light comes on and you can hear air blowing in the... (More)
Answer
not cooling and building ice in the inside saface
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE GSS20IEP Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
