Question about Dell 1125 All-In-One Laser Printer
Where are these taps located ?
Where are these taps located (inside/ouside/bottom ... of the tray?)
    President:
  • 1,447 Answers
What is tape such as docoments position if the machin is supported canon middile position or kyocera supported left position or you quary middle left or right
Posted on Jun 28, 2009
Water in bottom of fridge
The drain tube in any refrigerator is located right below the tray inside the evaporation compartment. A tray below the coils is made so that it funnels out the water. A hole is in the lowest portion of the tray. Junk gets into the tray and blocks the water from draining and so it backs up and flows down to bottom of the frig.
To fix the problem ya gotta remove the service panel and unblock the drain. If ice is blocking the hole you can sometimes run a copper wire down in the hole attached to the defrost heater which is a neat trick. If you would love a service manual I have numerous oneswhich are easy to access at: appliancejunkgoogledrive.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2013 | Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
I have a 2006 Kia Spectra5 hatchback......wondering if the master/slave cylinders are located inside the transmission or ouside? My mechanic can't tell me without looking at the car...?
So we are talking manual transmission clutch operation here?
Your master cylinder is located on the firewall, on the other side of the clutch pedal. Your slave cylinder is located next to the gearbox bell housing.
The slave cylinder:
The master cylinder:
Nov 06, 2012 | Cars & Trucks
Touchpad quit working for tapping
check for your trackpad settings mainly in the system tray icon on the bottom right corner and then right click the trackpad icon and make sure that tap to click is enabled.
if the icon is not there in your icon tray then look for it in the control panel and enable the tap to click option...
hope this helps
Jul 13, 2012 | Gateway Computers & Internet
My Frigidaire leaks water on the freezer side. A puddle appears every day on the floor in the front of the freezer. Inside the freezer on the bottom there is ice buildup. I think a drain must not be...
The defrost water is supposed to drain through a tube located in the bottom rear and flow into the flimsy plastic evaporation tray located inside the bottom trim panel. The tube may be clogged. The tray may be cracked or broken.
Feb 01, 2018 | Frigidaire PLHS267ZA Side by Side...
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
How do i do a master reset on a motorola blur
  1. Factory Data Reset
  • From the screen of your phone, open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  • Tap Settings.
  • Scroll down and tap SD and Card Storage.
  • Scroll down and tap Factory Data Reset.
  • Tap Reset Phone.
May 10, 2010 | Cell Phones
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
240 error
24x errors are paper jam error 241 tray 1 242 tray 2 ect. this means that the paper does not make it to the timming sensor inside the printer. this si usually caused by dirty pick wheels on the autocompensator located inside the drawer on the bottom of the printer
Oct 08, 2008 | Lexmark T522 Laser Printer
Dell 1125 All-In-One Laser Printer Logo
107 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
