Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Zodiac baracuda ranger making clacking noise and doesnt' move
I have a zodiac baracuda ranger. I bought it last summer and it worked great. It has worked great this year too until recently. It looked like it stopped moving, but it was just going very slowly even though the hose was still "bouncing". Plus it is making a clacking rythimic noice now. And it used to look like the big round disc that lays flat on the pool would kind of move like a sting ray, and now it just sucks to the bottom. I appreciate any help you can offer. thanks
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
  • 366 Answers
SOURCE: My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Posted on Apr 08, 2010
  • 333 Answers
SOURCE: The Zodiac Pacer Baracuda keeps turning on its
Probably not getting enough suction to hold it down on the bottom. Have you backwashed your filter ? Try that and see what happens
Posted on Jun 15, 2010
  • 990 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner only clean one
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Posted on Jul 05, 2010
jharwell668
  • 640 Answers
SOURCE: My zodiac baracuda gets caught
If these pool cleaners are getting stuck on corners or other obstacles, try these solutions. Try using Pool Pulse to lower the flow. If you are getting too much flow, the cleaner will stay along the edges of the pool and in corners. You might also need to adjust hose weights. You can adjust your return flow lines in the pool. If they are directed toward the corners, try moving them down and center to direct the cleaner in the correct positions in the pool.
Posted on May 09, 2011
Zodiac mx8 wheels are not turning
Hey Sergio,
If they wheels are not turning, the A or B side direction control has quit working. Normally they have drive 1 shaft in each run that wears down over time, losing friction on the shafts for the wheel to make the wheel rotate. If one side has gone out, I'd recommend replacing both and take a look at your wheels also. Normally these all wear out around the same time.
You're looking for something like this:
https://www.amazon.com/Baracuda-R0524700-Direction-Control-Replacement/dp/B00C404KFA/
https://www.amazon.com/Baracuda-R0524800-Direction-Control-Replacement/dp/B00C404LE0/
https://www.amazon.com/Baracuda-R0525100-Assembly-Replacement-Suction-Side/dp/B00C404LD6/
https://www.amazon.com/Zodiac-Baracuda-Swimming-Cleaner-R0526100/dp/B018GZEA7E/
Sep 14, 2017 | Zodiac Pool & Spa
Zodiac ranger has good suction but doesn't move
Usually if you have good suction with a Baracuda and no movement you either need to clear the diaphragm of debris, or replace the diaphragm if it's got a hole in it.
Check out this video (not mine) for how to pull the diaphragm out.
http://www.youtube.com/watch?v=FRR1Gsps8Js
It's pretty straightforward, just keep undoing things until you get to the flexible rubber bit. You have to check fairly carefully for holes because even the smallest opening means it's curtains for the diaphragm.
Good news is though that Zodiac should have a 1 year warranty on the diaphragm, which you can check by looking at the moulded stamp on the part. If it's under a year old your local dealer should just swap a new one for the old without any dramas.
Mar 16, 2013 | Zodiac Baracuda Ranger - Above Ground...
Baracuda alpha 3 has suction but will not move makes a humming noise.
Their is probally a small hole or tear in your diaprham and will need replacement. If you take it to a pool store they will probally do this for you just for the price of the part.
Jul 31, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac has suction but doesn't move
With these pool cleaners, that is often a problem with the flapper. Check the flapper to be sure that no debris is stuck. Debris can halt water flow and movement, making your cleaner get stuck.
Jul 11, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac g3 doesnt move
Diaphragm ripped. Replace with new one
Jun 09, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Feb 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
126 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
