Question about Magimix 5100 Cuisine Systeme Food Processor
Magimix blade is stuck
Blade is stick to the spindle of the Magimix.  Seems to be welded on.  Had the problem first with making dough, then stopped using the dough hook.  Latest problem occurred with making some pasta dough using the blades, when the the dough got into a ball, it was removed but the blade is stuck on.
  • Anonymous Mar 26, 2014
    the magimix blade is stuck firmly on it's spool
  • Suphiya Patel
    Suphiya Patel Jul 18, 2017
    similar problem here, while shredding parmesan, the stem stuck so bad, it won't come off...tried all the force we could...:( any help
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Posted on Jul 04, 2009
Where can I buy the dough blade in Malaysia ?
probably not as the original would be stronger that any glue used
find a shop that caters to kitchen trade and ask them
contact the manufacturer direct ( spares) and ask them where the distributor spares is in that country
Apr 27, 2016 | Magimix Food Processors
Pastry blade won't release
This is the kind of thing it would be very difficult to fix without being there in person. Do you still have the manual? It's possible there's some well hidden button or latch you have to hold in while you remove it. I tried to find a manual online, but was unsuccessful. I did see where you can purchase one - though I doubt you'll want to pay the $16 for it. But, just in case, here's the link: http://cgi.ebay.com/Cuisinart-Pro-Classic-DLC-10S-Manual-Recipe-Book-NEW_W0QQitemZ190147128664QQihZ009QQcategoryZ20673QQcmdZViewItem
Sep 07, 2007 | Cuisinart DLC-10S Pro Classic Food...
How to remove a stuck blade from a magimix
Correct repair is to replace both the blade and the motor shaft so drilling a hole sideways thru top of the blade to give you something to grip against is easiest. You need to protect the bowl because it's not necessary to replace that part. A couple of bits of wood across the top either side and then a screwdriver into each side of the hole you have drilled should give you enough grip to lever the blade off.
Sep 06, 2014 | Magimix 4200XL Chrome Food Processor...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Dough hook stuck
New shaft cover req about £10.00 you will proberly have to replace any damaged blades aswell.
Sep 05, 2008 | Magimix 5100 Cuisine Systeme Food...
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
Jun 30, 2008 | Bravetti Quad Blade Food Processor
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Magimix 5100 Cuisine Systeme Food Processor Logo
2,775 people viewed this question
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
