Question about Diesel Watch DZ7071
Set time un-able to set the time back on this watch
Re: set time
I have just posted this problem on here myself but have also just found the solution after searching the internet so here it is..........
Hold down the top left hand button which is for the light and then a menu should come up saying 'LIGHT' & the option for on or off, ignore this & press the bottom left button, the next option is for the 'CHIME' & on or off, press bottom left button again & the option for 'TIME' comes up. Use the buttons on the right to alter the time until it is correct and then press the bottom left button again for the date and select the correct month and day and year and then you are all set up! Hurray, a watch that tells the time, im chuffed!
Posted on Nov 01, 2008
Re: set time
I bought the watch but i haven't got a manual. Could you plese send it to my address which is
Thank you
Posted on Dec 25, 2008
  • 1,463 Answers
Re: set time
they may have the manual which will give you some idea.
Posted on Nov 06, 2007
0 characters
3 Points
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
I don't know what size battery to buy to replace the one in my Ann Kelin watch, it says Y121E
mcdevito75 Here, Your Ann Klien watch may take a 364 or 371 battery, Best Bet is to look for a small watch repair shop in your area, the $15.00 cost is worth it as you would have to remove the back of the watch then un screw the hold for the battery, your time and effort really isn"t worth it, plus the new battery will last a year maybe even longer.
Feb 09, 2011 | Watches
How do i set the time on a dunlop sports watch?
Ma montre , spur DUNLOP dun 103 g10 , est pourvue d'une feuille explicative concernant un mod?le diff?rant !
2 personnes ont pass? des heures ? essayer de la r?gler sans succ?s
comment ? puis-je la rendre fonctionnelle ?
Merci de votre r?ponse
Meilleures salutations
50, rue du Premier-Mars
CH-2206 Les Geneveys-sur-Coffrane
Sep 23, 2010 | Bulova Watch
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
How do you pull the crown out on and invicta watch
mcdevito75 here, Your invicta may have a screw down crown that adds water proof protection to your watch, try to un-=screw the crown when un- screwed then pull up to set time.
Jun 26, 2010 | Invicta Subaqua Noma Iii S
Im trying to adjust the time because it stopped when i took it off for a day. Im not sure how i can change it because the adjusting knob is not popping out.
mcdevito75 here, Tissot a very, very great name and watch, a you know most stems pull out to set the time, some watches have a screw down crown this adds to it"s waterproofing as there is a gasket under the crown. Maybe your Tissot has this screw down crown, simply un screw the crown then gently pull up on the crown to set the time. If this fails, see any Jewler for help, doN't mess with the watch to much a syou or anyone could wreck it, and Tissot is very expensive.
Jun 24, 2010 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
I have a problem pulling out the stem to set the date on my Roadster. Can you help? I can't seem to grasp the stem securely enough to pull it out. Thank you
mcdevito 75 here, you should be able to get a finger nail just under the stem to lift the stem to set the time, day/date, first be sure the stem isn"t a screwdown type, gasp the stem and turn it to see, if it is a screwdown type, simply un-screw the stem then pull it out to set the time, day/date. If all fails your local or any jeweler can help.
Jun 16, 2010 | Cartier Roadster W62016V3 Wrist Watch
Military Time
Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
Jun 17, 2008 | Bulova Men's Watch
1) un-screw the pin by turning it towards you, until the spring pops it out. 2) pull the pin out to the next notch 3) turn the pin towards you and watch the date change (if the minute hand is moving when you turn the pin, you pulled out too far).
Apr 15, 2008 | Rolex Explorer II 16570 Wrist Watch
Diesel Watch DZ7071 Logo
558 people viewed this question
Top Diesel Watches Experts
Arturs Kalnins
Arturs Kalnins
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
