Question about Craftsman Garden
I have a problem a Craftsman 18hp 42 in deck--it stops running.
I have a problem a Craftsman 18hp 42 in deck, 917.273762. It appears the engine isn't getting gas. It just stops running. Fuel filter has been replaced. All other filters are clean. The plastic/glass in the fuel filter line has no gas in it when the tractor stops running. It seems to happen after running for more about an hour, as if it's because it's hot. Let it sit for a period of time and it's good to go--but only until it's hot again --or whatever is causing this. Any ideas?
  • lkw1278 Jun 28, 2009
    Holy cow--that's it? Gosh, thank you so much. I'll try the re-route-- but on a 2 yr old tractor you'd think that would have been taken care of in the design. Thanks again, I'll try your suggestions.
    We have replaced the fuel filter and the fuel hose-- and neither fixed this problem. Is there a type of tubing/hose that is more heat resistant that we should look for? I misspoke previously on the age -- the tractor is almost 5 yrs old. Still, doesn't seem old enough for a hose to rot/crack. I think we'll forgo injecting air and just replace the hose again. I appreciate you sharing your thoughts and experience about this problem. Thank you.
    Scholar:
  • 48 Answers
The problem is called vapor lock. It occurs when the fuel in your supply line is vaporizing just before it gets to the fuel pump and the fuel pump is not designed to pump vapor so you run out of fuel.
Possible solutions are to re-route your fuel line so that it doesn't get hot from the engine and/or run the mower during the cool parts of the day only. It might be as simple as getting some new gasoline as winter bought gasoline will always vapor lock if used in the summer time as they alter the formula for gasoline on weekly basis to stay ahead of vapor lock problems nationwide. Way back when cars were mostly carbureted it was a MAJOR summer time pain. The three options given above remain the best solutions for this ages old problem.
Posted on Jun 28, 2009
  • melee5 Jun 28, 2009
    Three days ago I did replace the section of fuel hose on one of these between the fuel filter and carb. It had cracks that would let air into it causing a similar situation to yours. I found the problem by injecting air from an air hose nozzle into the gas tank with a rag taking up the major dimension difference between the air nozzle and the 2 inch gas cap which was removed. Be extremely careful not to blow up the tank or otherwise cause excessive pressure on the fuel system, but when I then looked for any leaks, I found a half-cup of gasoline on the floor of the shop under the carb area which is plenty dangerous enough. I you find ANY wetness along the length of the fuel hose it is time for a new hose, mine cost me $1.60 a foot at NAPA for generic 1/4" gas hose. You don't have to pay more.
    As a prophylactic measure you also don't need any excuse for just changing out your old fuel lines...
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman 46" 18hp lt 2000 the blade engaging cable broke and i replaced it but now it won't start. it try but it spins alittle like it wants to but stops. i took the spark plug out and it spins...
sounds like valves are out of adjustment. but since you just put a cable on it be sure it is on correctly and the belt releases the blades because if the belt is to tight it will not allow the engine to turn over past the compression stroke as you are saying.
Nov 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
537 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
