Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
A
Anonymous Posted on Jun 30, 2014
WATER HEATER NOT HEATING MODEL NO 8TV40-2
SERIAL NO RM0108235899
2answers
Rheem serial R0996B30824 Model 7130S in MFG Home 40 gal how old and why does hot water run out after one shower . Just bought modular home need help
If the water heater is electric; BE SURE AND TURN OFF THE CIRCUIT BREAKER TO THE WATER HEATER, DOUBLE CHECK THE VOLTAGE AT THE WATER HEATER WITH A MULTIMETER BEFORE DOING ANYTHING ELSE!
Here's a good video on how to test the heating elements.
To check the reset button.
To check the thermostat.
Why do I suddenly have no hot water in my electric Premier Plus water heater?
1st check the circuit breaker that supplies power to the water heater. If that is OK then check and see if you have power to the heating elements on the water heater. If not then check and see if the thermostat on the water heater has power to its connections and verify that it is calling for the water to be heated. Last if all these checks are OK then you must have a burnt out heating element. Some can be replaced but you will have to drain the water from the heater before replacing the elements.
Rheemglas standard energy miser electric water heater model #81vr-80 gal serial #RH0501c00664. Does it have two heating elements and where are they?
it does have 2 elements they are located under the 2 panels on the heater you will find them under the covers on the front they will be connected to the thermostats follow the wiring. besure to turn off the power before working on it and use a tester to double check
How to get a warenty replacement unit
First, you'll need to gather all pertinent info- including model / serial number and any paperwork indicating date of installation or purchase.
Next, go to Rheem's website. There is help there to assist you to locate your heater's model and serial number if you are unable to / unsure of where to find it. If you live in the U.S. and have the model / serial number data, you can go to the Homeowners Resource Center page and click "Water Heating Product Warranty Verification" link inside the Warranty Section. If you live in Canada, you cannot use the online verification and should call 800 263 8342 instead.
I hope this helps & good luck!
2answers
Need to know the year of my tank RR410T
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
Where are the heating elements on an 80 gallon electric water heater? Model number : E 2 F8 0 H D 0 4 5 V
I don't know that model number.
Tank-type water heater elements are located behind panels on side of tank.
Open following link to help troubleshoot electric water heater problems:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
The water heater label also shows element wattage, brand, voltage, serial number, and type of operation.
For example 5500W elements, non-simultaneous, 240V are typical ratings found on water heater.
5500 Watt would be replacement element size.
Non-simultaneous would indicate that both upper and lower element are not turned ON at same time.
240Volt is typical voltage for water heaters.
Serial number carries date-of-manufacture, based on brand.
For common brands:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
I am trying to drain my electric water heater: Servistar, model no.06443 serial no.0496B02329, watt: 1-PH,Upper 4500 240 volts only, Lower 4500 Cap. U.S. Gallons 50 Total 4500 I closed the cold water...
Hi Karen, think of the water heater as a straw....if the straw has liquid in it and you put your finger on the top, the liquid doesn't come out. If you open up the relief valve, air will allow it to flow freely. The relief valve has a metal lever on it, usually on the top of the water heater (if electric).
Top Audiovox Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
