Question about Roper REX4634KQ Electric Dryer
My dryer will not turn on.
It was working a few minutes ago and now it will not turn on.
Dryer will not work when i pres the start button
Posted on Jul 11, 2009
What could be wrong if the dryer will not start?
make sure that the door is properly closed as there is a micro switch at the hinge that will not allow anything to start if it is not in the right position
Apr 07, 2015 | Dryers
Screeching sound coming from Maytag dryer. Blower wheel, motor?
Probably bad motor if dryer is shutting down after few minutes of operation
Aug 27, 2017 | Maytag PYG2300A Gas Dryer
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
The dryer is started and the flame starts to dry the clothes. The dryer runs for about 10 minutes then the flame goes out. The dryer continues to run but the flame is out and does not turn back on. ...
Remove the entire venting system and thoroughly clean the lint out. This does cause this problem you have for no heat after running for a few minutes
Sep 01, 2010 | Estate EGD4300VQ Gas Dryer
Dryer will heat and spin. After a few minutes it stops. Try to push to start button and nothing happens. I wait about 20 minutes and it will start again. What is the problem ?
Mine was doing the same. I got a bit of a rattle noise in the timer when I'd try to restart it though. First I unplugged the dryer, I took the control head off, then I took the timer out, and opened it up. Found that 2 of the copper contacts were covered in black soot and had a little corrosion on them. I took some fine grit sandpaper and sanded the contact only till they were smooth and clean. I only did this a short while ago but seems to be working so far. It hasn't prematurely shut off and the timer is turning again.
Aug 26, 2010 | Kenmore 62602 Electric Dryer
While drying the dryer stops running every few minutes.
Have you checked the hose and ductwork to make sure it's all clear? It might not be able to ventilate.
Mar 06, 2009 | Fisher and Paykel DGGX1 Electric Dryer
It shows 8.8. and does not start
After having this problem I believe I found a solution. I think the problem is related to tha ambient temperture of the room where the dryer is located. If it's too cold, you get the 8.8 error. When I first had the error it was at 7:00 in the morning trying to dry some clothes that were in the washing machine overnight. I couldn't get the dryer to work and had to go out for a few hours. When I got back around 11:00, the dryer worked fine. The only difference I could think of was that it was warmer than before. So a few weeks later I rememberd this and tried to test my theory. I waited for a very cold morning and tried the dryer and got the 8.8 error. Then I took a small patio table heater and turned it on in front of the dryer for about 20 minutes. The dryer fired up right away. I've used the same routine whenever I get the 8.8 error and it's always solved the problem for me. Hope this helps
Dec 11, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
153 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
