Question about Kenmore Washing Machines
I get oil stains on some items of clothing in each wash. I've tried discontinuing use of fabric softener as suggested by Sears, and I've also tried several loads of CLR to clean any grime or rust build up. After that I was told its probably the transmission leaking fluid. How much does this type of repair cost (its a 7 year old kenmore 80 series) ?
If this is a front loader, it is the bearings on the tub shaft. I just replaced a set on my front loader for the 2nd time. It is not a real easy fix but mine cost only cost 25.00 for the 2 bearings and seal. Not from Sears.
Posted on Jun 28, 2009
When i do a white wash some items come out with dark stains on them
Fabric softener will stain man-made fibres such as 100% polyester, and should only be used on natural fibres, ie, wool, cotton, linen.
Aug 08, 2014 | Daewoo Washing Machines
CLOTHES COMING OUT OF WASHER WITH DARK STAINS
Hi Lynn, this is AP.
I understand you are seeing stains and lint on your clothes once removed from your top load washer, model FWS833A. There could be several culprits causing this to happen. To confirm, are the stains not being removed during cycle or do you believe the washer is the cause of the stains? If you believe the stains are being caused from the washer it could possibly be undiluted liquid fabric softener poured directly on fabric. Something more serious could be a broken transmission causing oil to leak in the tub.
There are some basic troubleshooting tips for lint to check such as undissolved detergent can leave residue on clothing. Separate clothing items which shed lint from items which attract lint. Permanent press, synthetic, knit and corduroy items will pick up lint from towels, rugs and chenille bedspreads. Make sure to Use correct amount of detergent, water temperature and water level.
There are some simple troubleshooting tips listed above and in your owner's manual, if you find they do not resolve your concern I would recommend contacting a local authorized technician to inspect the washer.
Thanks,
Mar 30, 2014 | Frigidaire FWS833A Top Load Washer
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
Stains on clothes after washing. Appears to possibly be oil residue. Is there a rubber seal or part that may be leaking inside the drum?
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Aug 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch wfk2801 yellow spots on washing
That sounds like oil but there's nowhere the oil would be coming from except the rear bearing but that would be more of a grey or black colour.Is your fabric softener yellow.it could be fabric softener.try not using any for a couple of loads & see.I don't know if the dots are washing off but fabric softener stains will normally wash off.oil won't.
Jun 04, 2010 | Washing Machines
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Kenmore Elite top load set
fabric softener will leave oily looking stains on certain fabric. oil stains will not wash out.i do not recommend using softener in washers it gums up everything!
Nov 03, 2007 | Kenmore 22422 Top Load Washer
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Oil Like Stains on Clothes
possibility is that the bearing seal is breaking down and oil from the bearings reaching the clothes. if so, the bearings will shortly follow. not an easy job and you are faced with a bill if i'm right
May 11, 2007 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
