Question about Dryers
I have the exact same problem; dryer gets hot but won't dry
I have the same model number, kenmore 110.64212200. I cleaned the vent all the way to the outside. When I run the dryer, the heating element gets red hot, but the clothes need 2 cycles to dry. When I open the door mid cycle, I can see the glow of the element, but it does not feel warm inside the drum.
    President:
  • 1,136 Answers
Hi, While the dryer is running, remove the lint screen and put your hand in the opening to see if there is air moving. It is safe to do. You should feel a good amount of air sucking past your hand. It is possible that lint has built up inside the lint screen housing. You can also remove the vent from the rear of the dryer and see if it makes a difference in the air flow past your hand.
You mighr have to remove the rear panel and then remove the 4 screws holding the lint screen housing to the bulk head. You will also need to remove the 2 screws under the lint screen door.
Pull the housing away from the bulk head and make sure it is cleaned out and make sure there is nothing in the motor blower wheel as well. I have also sen something get hung up inside the dryer blocking the hole on the right side rear where the air goes into the lint screen.
I hope this helps you. There is air flow blockage somewhere.
Please let me know if I can assist you further.
Vic
Posted on Jun 28, 2009
2 Suggested Answers
  • 56 Answers
SOURCE: Kenmore dryer 110 708 12990 Igniter glows, but
replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
Posted on Jun 30, 2009
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
The heater appears to be heating when drying but it takes 2 to 3 times to get a load dry? Thank you for the help. Scott Model 68712894
if your dryer feels hot inside and the drum tumbles then you have a blocked vent. check that the venting blows to the outside. do this test. unhook the vent behind the dryer, dry a load of clothing and if it dry on the first time then you know the house vent is clogged. cleaned or if you live in an appartment have maintenance clean.
Feb 12, 2011 | Kenmore Dryers
Our kenmore electric dryer model number 11066662501 is not drying. The vent has been cleaned. It's also not getting hot.
mine too...same thing. I took off the entire back panel and cleaned everything. Seems to run fine, just no heat...
Jun 25, 2010 | Kitchen Ranges
Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
May 26, 2009 | Kenmore Dryers
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Won't dry clothes
Try running the dryer with the vent pipe unplugged. There should be a lot of hot air coming out, if not the insides need to be cleaned. If it really moves air, and dries a load ok unhooked, your vent is clogged. Clean it if you can. If you can't, look into a lint trap that will work for your situation, some have a water trap, some are good filters, etc. If the air is not hot, some of the electric element may be bad. If it's gas, it could need a tune up and cleaning inside.
Apr 24, 2009 | Kenmore Dryers
I have a kenmore elite dryer model 110 62062100 that has been getting hot (cabinet get very warm on top) and does noy dry all the way. it shuts itself off before its dry. any idea what part is needed?...
most of the time when this happens it is from a clogged wall vent or clogged dryer vent or clogged lint trap,check and clean all 3 and let me know how it does-mike
Apr 22, 2009 | Kenmore Dryers
Kenmore dryer model 41780042990
sounde like you have a clogged vent line be shure the vent hose is not cinked in any waty that would restrict the air flow. Next turn the dryer on and make sure you and a good flow of air out side the house if the air is not blowing out the vent out side you will need to clean this out or have it cleaned.
Jan 20, 2009 | Frigidaire FEQ332E Electric Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
Top Dryers Experts
