Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Seagate Barracuda 7200.10 500GB Video Included. Humming, Wobbling
Not detected by anything, hooked it up via usb directly, and still didn't work. The drive spins up and everything. Has not yet been opened, but I do plan on trying to repair the drive myself sometime.
500GB 7200.10 Barracuda
Stopped working when I accidentally tripped over the drive.
I'm hoping someone could diagnose the drive simply from the sound. Is it the heads? The platters? Thanks, let me know if anything else is needed...
http://www.youtube.com/watch?v=FTWcdBCCgv8
Please watch entire video to hear dramatic rumbling sounds.
  • mikespax
    mikespax Jul 14, 2009
    Please don't answer unless you have watched the video.
  • 29 Answers
Brother,it is a firmware problem for seagate drives,the 7200.10 has a typical problem of firmware,once it currupt,then it cannot be detcted by the BIOS or PC ,or showing 0GB or less capacity when connected,so you can use some useful tools such as HD Doctor for Seagate to repair it,this problem is very common but less tool can deal with it till now.
Posted on Jul 09, 2009
My new Seagate Barracuda 7200 does not
Hi Simlei.
If its a modern, fairly new drive, it should have built-in firmware, without a need for extra drivers.
If you OS is old the OS itself may not be recognizing the drive's 'language', especially if the bus-width differs, ie 16/32/64bit.
As 1 TB is quite recent on SSD's, I guess its new.
My 1 TB Toshiba just plugs into USB and Win Explorer detects it as a storage drive.
Regards, Clive.
May 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a seagate barracuda 7200.10 750gb s/n 5qd41xp3 st3750640as p/n 9bj148-568 origonaly came with incloser no computer reads it ether conected via the usb cable and card or hooked strat to the...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Jan 20, 2011 | Seagate 750GB ST3750640AS SATA300 16MB...
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Cannot detect Seagate Barracuda 7200.9
The motherboard has two SATA connectors but they only go up to a 150 MB/s data transfer rate.
Your Seagate however, is engineered for 300 MB/s data transfer.
Download the Seagate manual for this drive and you will see the diagram on the last page that shows how to place a jumper on the drive to make it work at 150 MB/s.
Mar 21, 2010 | EPoX EP-8HDAI PRO VIA K8T800 CHIPSET...
My 320 gb ide hdd is not detected to my computer but it is detected with usd external cables .ibut the problem is the full memory is not shown only 1 partition of 48 GB shown rest of 3 partition detail...
old computer can work till 160gb as directly connected with serial cable, but when u connect with usb, then it dont act as serial ATA, the technology change if its a PIII computer then it would not work.
Feb 08, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
7200.10 500GB Video Included. Humming, Wobbling, Beeping Sounds
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware/ follow indications carefully
Jun 25, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Harddrive is not detecting bios
get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
Apr 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
567 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
