The fans,dvdrom,hard drive and lit on board comes on but no video its a black screen
SOURCE: Asus p5w DH Deluxe: updated to new bios 2704 now only black screen on boot up
brophylad,You sound like you know your way around a PC so please do not be offended by the suggestions below that you may already be aware of to begin with.
Use the PC your are using to communicate with us and download the older bios and create a bootable floppy or CD, Nero's bootable image is best as it recognizes NT partitions, and try flashing with the old bios. Otherwise, when I've had a board on the bench with this issue I've had to get a replacement bios chip which is rather easy to replace or Asus has replaced the board for me under warranty or for a rather fair price to replace with a refurbished board.
Anyway, try this again: remove the button battery and turn off the rocker switch on your Power Supply and remove the power cable. Leave all this disconnected for several minutes. Re-insert the battery, reattach the power cable and turn the rocker switch back on and attempt a bootup. If this fails to get you to a bios setup screen the CMOS chip has failed, permanently or is glitched, with the later being my guess.
Phone Asus at 502-995-9883 and have the serial number for your board, located on the inside of the case on top of the parallel port socket. I've phoned them many times over the years and they are quick. They'll most likely will give you a post bypass keyboard sequence if there is one for your model or give you a RMA immediately. I've never found Asus slow to replace a board from the RMA department.
The above phone number is for tower boards, for notebooks (they make great notebooks and sell white boxes as notebooks) call 510-739-3777 x5110.
Best Regards and good luck,
Worldvet
SOURCE: How to reset Asus PC-DL Deluxe BIOS
hopefully you have the manual....you'll need to locate the jumper for Cmos reset.....basically you move the jumper to reset the Cmos then move it back again
SOURCE: ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
SOURCE: pci express will not work
U WIL HAVE TO CHANGE THE JUMPER SETTINGS ON THE MOTHERBOARS...I HAD THE SAME PROBLEM..REFER TO YOUR USER GUIDE...IT HAS GOT DETAILED INFORMARTION
