Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
DF3015 electric fireplace insert- unit is plugged into power outlet but does not turn on.
    President:
  • 1,723 Answers
The blower is controlled by a thermostat and will only come on when it's hot. If still does not come on check thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 01, 2009
How do I get the dust off the logs on the gw2078?
Ref. link:
http://homemarketdeals.com/how-to-clean-an-electric-fireplace-insert.htmlWARNING: ALWAYS DISCONNECT FROM THE POWER SUPPLY BEFORE CLEANING THE HEATER.
For general cleaning on the unit, simply use a soft clean duster. Never use abrasive cleaners. The glass-viewing screen should be cleaned carefully with a soft cloth. DO NOT use proprietary glass cleaners.
To remove any accumulation of dust or fluff on the fireplace logs, the soft brush attachment of a vacuum cleaner should occasionally be used to clean the outlet grill of the fireplace. To access the electric fireplace logs follow these easy steps:
1. Remove the 4 screws on the front panel.
2. Carefully remove the front glass panel.
3. Unscrew the rosebud log screw.
4. Wipe and clean the log set with a damp cloth or a soft clean duster.
5. Replace the rosebud screw, glass panel and screws and enjoy!
Nov 26, 2017 | The Computers & Internet
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
How do I clean the inside glass on my electric fireplace
To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well.
Cleaning Steps
1.Disconnect from Power Supply Before beginning to clean your electric fireplace, turn the heater off and allow to cool completely. Always disconnect the electric fireplace from the power supply before cleaning.
2.Check the Electrical Components Check any wires and plugs to make sure that they are not worn or frayed. This is a rare occurrence, but can become a fire hazard if not addressed. If this happens, consult a professional to repair or replace before using your electric fireplace again.
3.Clean the Heater With a clean, dry cloth, wipe down the surface of the heater. Using the soft brush attachment of a vacuum cleaner, gently clean the heater outlets. This will remove any dust or debris from the heater and keep it running at top performance.
4.Clean Both Sides of the Glass Follow the instructions in your owner's manual for removing the front glass panel. Once removed, you can clean both sides of the glass. Do not use abrasive cleaners, as they will scratch the glass. Dust can be easily removed with a clean, dry cloth. Fingerprints or other marks can be removed with a damp cloth; dry the glass with a lint free cloth to prevent water spots from forming.
5.Dust the Interior Dust may accumulate inside your electric fireplace, like any other unit in your home. To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well. When you are finished, place the front glass panel back onto your fireplace following the instructions in the owner's manual.
6.Remove the Soot Just kidding! You never have to worry about dirty, grimy soot with your electric fireplace. Instead, just relax and enjoy!
Nov 14, 2017 | Miscellaneous
Heat does not work shuts off after ten secounds
ClassicFlame 36EB220-GRT 36" Traditional Built-in Electric ...
www.amazon.com/ClassicFlame...GRT...Electric-Firep...
Amazon.com, Inc.Save Big On Open-Box & Preowned: Buy "ClassicFlame 36EB220-GRT 36" ... TheClassicFlame PRO 36" traditional built-in electric fireplace insert, 240 volt, ... Heatingyour entire home all day may not be the best economic choice for your utility ... Youcan shut off the heated air blown to different sections (or 'zones') of your ...
Amazon.com - ClassicFlame 36EB221-GRC 36 ...
www.amazon.com/ClassicFlame...Electric-Fireplace/.../...
Amazon.com, Inc.
Rating: 4.1 - ‎7 reviews
36\" Builder's Box Electric Fireplace Insert The ClassicFlame builder's box features... You can shut off the heated air blown to different sections (or 'zones') of your home... 36EB221-GRC 36 inch contemporary built-in electric fireplace insert will .... Wedid finally get the pieces after about a month, and the unit is working now, ...
ClassicFlame 36-Inch 120V Traditional Builders Box ...
Jan 18, 2016 | Classic Flame PRO 36EB110-GRT 36 Inch...
Vermont casting fireplace vcef33
You could take a table lamp or a drop light a electric drill or anything similar,and see if you can unplug the insert and plug one of these items in and see if the plug works
I am taking for granted that you can get to the plug without having to pull the insert out or at least not all the way out
If you can't do that
Turn the breaker off to that circuit pull the switch out and make sure nothing is touching
Hook a tester to the wires and then turn the breaker on and see
If you have power to that switch turn the switch off and on watch the meter and see if it does turn on and off
If you have power coming out of the switch.
and you can't reach the plug then you only option would be to pull the insert
As for a fuse there may be one but not look like what you are thinking a fuse will look like it is usually a temperature fuse that is shaped similar to a diode the symbol for it can be two ways
it could have what looks like a c laying on its side upright and also another c beside it on its side aiming down like a snake crawling. The other symbol looks like a rocket with no fins on its side with a with a what looks like a T laid sideways coming off one end
Oct 20, 2013 | Heating & Cooling
How to replace my charmglow electric fireplace with a gas insert
Check your local building codes for restrictions. You MUST have the proper exhaust for a gas unit. There may also be flooring and wall requirements that need to be changed.
Jan 18, 2013 | Heating & Cooling
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
I have a Dimplex Fireplace with remote control. I believe the model number to be BF335STP/DXP. We have had this fireplace for almost 2 years. When we have a power outage you have to follow some...
There was a recall on some of the remotes. Check to see if yours is one of them. If you take the plug put of the remote box, and just plug it directly into the wall,it should work.
Nov 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
verify the breaker is on (reset) then power up and verify voltage with a meter, there are safty devices that will keep the unit from energizing other than the switch
Jul 06, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
569 people viewed this question
Top ACE Heating & Cooling Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Tim Whalen
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
