Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet 2165 with a Briggs & Stratton shuts off when hot. Appears to be vapor lock, as can see fuel filter emptying. After filter cools, it refills. Anyone have a solution?
    President:
  • 1,776 Answers
It could be vapor lock. Vapor lock is a condition where the hot gasoline turns into vapor bubbles either in the fuel line or carb. When it happens, the vapors will cut off fuel flow thru the carb, essentially causing the engine to run out of fuel. You should re-route or isolate the fuel line away from the heat of the engine and install an inline fuel filter close to the carb. Also make sure that the cooling fins are not clogged up with trash or something that is causing the engine to overheat. I would also check the gas cap. Make sure the vent is clear and clean around the gasket in the cap. This can sometimes cause similar problems. Hope this helps and good luck.
Posted on Jul 14, 2009
I have a Cub Cadet Model 364 with a 18 H.P Briggs & Stratton motor. It runs fine for about 20 minutes. Than starts hesitating. Like the motor wants to stall out. Help!
Firstly, try to run the engine without cap on the fuel tank. If it stays running well, clean out the ventilation hole in the fuel cap ( or replace the fuel cap ).
Check for dirt in the fuel tank, fuel tank connections, hose, strainer, filter. Clean everything!
Check if you still have sparks when the engine stopped from itself.
Check if you still have compression when engine has stopped from itself ( valve settings too close )
Sep 28, 2016 | Cub Cadet Garden
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Apr 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a cub cadet #2135. Had it overhauled last winter--new blades, new battery, new pto switch and changed oil. Recently the mower runs for about half an hour and then quits--seems to be too hot--but i...
Maybe your fuel is getting too hot and causing it to be vapor locked. Check to see how far the fuel line and the fuel filter are from the engine on the approach to the carb. If you are able move the line away some. You may want to move the fuel filter closer to the carb. so that any vapor bubbles can come out in the upper part of the filter allowing for free flow of all the way to the carb.
If really helpful, please rate.
Jul 12, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
14 hp briggs runs fuel filter dry every 15 minutes. have to blow into fuel tank to fill filter up then it runs for a while again. whats up ?
Sounds like the tank is not venting. Try leaving the cap a little loose and see if it stays running. If it does, either the vent for the tank or a vented gas cap is plugged
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
My Cub Cadet 2185 only runs about 10 minutes then dies. Engine area is very hot. I have cleaned everything very well and put in a new fuel filter. Fuel pump is working.
Inspect the inside of the fuel tank, where the fuel exits the tank. There might be dirt/crud clogging the line. Also, if the fuel line is too close to any exhaust pieces, or is against the engine, it will boil the fuel and cause it to vapor lock (and stall out). Look for these items and hopefully it will cure your issues. Also clean off all dried grass/dust from intake screens. Also check your oil level. Make sure its in the good range, not over or under filled.
Jun 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,055 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
