Question about EliteGroup 661FX-M Motherboard
Load a new hard drive
I have a 661fx-m v1.08
when loading windows xp it checks and loads up to,ready to load windows
then shuts down ??
I have reset the bios but still get the same problem ?
I still have the other hard drive same brand and still works
I have the same software on this hard drive but cannot reload software.
I set them both up 4 month ago with the basic software in case one faied
but it won't reload , I bougth a new hard drive ,but I'm having the same trouble , its shuts down after shecking out computer hardware ,and ready to load windows ?/
  • 41 Answers
Hi Dutshy1,
On back of the hard drive did you move the jump on your main hard drive and set it to Master and your secondary hard drive set to Slave.
Where the jumper is suppose to go is printed on the sticker on top of your hard drive.
The jumper is the little plastic thing on the back of the hard drive connecting two pins together next to the power port and where the IDE cable is suppose to connect.
let me know if that works.
Posted on Nov 18, 2007
Can't install windows XP on new hard drive
That problem is from HDD, It can be bad sector on MBR \ on line for boot record\. Change your hard disk , if it in warranty , will be well.
Nov 24, 2011 | Biostar G41D3C LGA 775 Intel G41 Micro ATX...
I have windows xp media center edition 2005 and i have downloaded a driver for my new monitor lg E2250 and my computer have shut down.. since that i cant load windows i cant boot in safe mode for a...
Can you reload last known good configuration? Tap F8 as the computer boots up to pull up safe mode, etc options. If that doesn't work, you're SOL. The fact you cannot even boot up safe mode pretty much means you're hosed. If you have files on that hard drive, I would recommend pulling the hard drive out and getting the data off w/ a hard drive adapter. Once all files saved, I would wipe the drive and reinstall the operating system. Sorry. Situations like that ****.
Mar 12, 2011 | Microsoft Windows XP Media Centre 2005 for...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
HP530 shuts down within 15 seconds as it loads XP
Probabpy an XP problem, start XP in safe mode (press F8) as it is loading.
If it runs then it is probably a driver problem. Try restarting in the last good configuration. Keep posting until the problem is resolved.
Aug 17, 2009 | HP Computers & Internet
My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
ur laptop came with pre loaded OS as XP
then do this without disk
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
pls let me know and rate me FIXYA for help
Mar 31, 2009 | Sony VAIO VGN-FS920 Notebook
Can not install windows xp
hubag, you need to check your bios. At boot up, press the delete key every 2 seconds & your bios will load. Make sure your SATA drive, (s) are listed example: {if your SATA drive is a Seagate the bios will show it as: ST3250823AS}. You should unplug any IDE hard drives connected to the system while installing Win XP. The Southbridge integrates a Serial ATA host controller that is SATA v1.0 compliant, supporting Ultra DMA 150 (SiS964 only). If you do not have your manual you can download it here at:
Once the bios is set & see's your SATA drive so will windows.
If you can not set your bios to list your SATA drive windows will never install on your SATA drive. You can also use the above link & down load drivers, including a RAID driver.
Feb 21, 2008 | EliteGroup 661FX-M Motherboard
EliteGroup 661FX-M Motherboard Logo
74 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
