Question about Acer P221W LCD Monitor
ACER P221W No display and power light blinking
Initial symptom was the monitor would not come on, but the computer was running. I knew this because I was running a networked printer off the system. A couple of days later, the computer seemed to die as well. Disassembled the computer and found the fan on the video driver card smoked, thus my thoughts led to the video card, nvidia 8500, so I pulled it since I also have an on board video interface. When removing the card, the computer came back up, but the monitor still seemed dead, with the blinking power light. Tried to hook the monitor up to my laptop still an no go. Wondering if it might be something simple on the monitor, or if I need to just put it six feet under and install a RIP tombstone.
  • wschupp38 Jun 28, 2009
    Pulled the monitor apart this morning, working through the maze of snapping plastic - wow. Everything on the power supply card looks fine. Checked the output voltages, all 4 of the 5V outputs are good. My thoughts are leaning toward your call on the video card. What is the best course on the video driver board, with all the surface mount technology? Try to repair or replace? Is this something that you may be able to provide/repair? Part number 2128P and 77UM4D01650
  • 1,684 Answers
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If the monitor does not have any bad caps then I would be that when the video card died it sent a spike to the monitor and killed the driver board. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jun 28, 2009
A vertical line in the middle of my Acer P221w monitor
dead pixels?? although im told dead pixels are red.
Feb 16, 2013 | Acer Computers & Internet
I have a p215hlcd monitor and cant find the off\on switch?
Look "underneath" the bottom-centre of the display.
Look for a "silver" coloured button at bottom-right of the face.
Look for a "rocker" switch along the right-side edge.
Or, ask a pre-teen girl who wants to update her Facebook. :-)
Oct 24, 2010 | Acer P221W LCD Monitor
Picture changed to a blue dominant picture
disconnect the monitor from the system and check if all the pins of the cable are not damaged. if not damaged, then check the device manager for exclamation marks, try and reinstall the drivers
steps to open device manager;
click Start select Run type Devmgmt.msc press Enter
Apr 21, 2010 | Acer 22" X223w LCD Monitor
I would like to know how to dim the light /screen on acer p221w monitor.It is very bright and i would like to know how to dim it
You should have some buttons on the front of the monitor, one of them is probrably a menue button which should allow you to adjust alot of the monitors settings from within there.
You can always download a manual by googling your monitors model number for exact instructions.
Nov 08, 2009 | Acer AL1916W 19" LCD Monitor
Screen resolution for Acer P221W
1680x1050.
It also depends on the video card how high the resolution can go.
That's the max resolution though.
Here's the complete specs for your monitor.
Have a good day!
Jul 18, 2009 | Acer AL1916W 19" LCD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Monitor Problems
It has a 3 year warranty.
Mar 15, 2009 | Acer P221W LCD Monitor
Acer P221W LCD Monitor Logo
956 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
