Question about Orion 8004 Car Audio Amplifier
Amplifier repair i have a rockford fosgate amplifier. it recently stopped working and i would like to fix it on my own. any suggestions.
  • 4 more comments
  • Michael Sanson
    Michael Sanson Nov 12, 2007
    I keep blowin the same 2200 uf 80v. power supply Caps, (same 2 out of 5)
    I unhook everything before it does more damage.
    I replaced the blown 2 with the same rating, 100v this time, it playes fine until it basses hard for a few then blows them again.
    what should I look for next?
  • phantom007 Nov 22, 2007
    The amp just stoped working one day.So i took the panel off and hooked it back up again. Then i noticed the the red light would blink on and off, and the fan inside would also work but not really. It would slowly pick up speed as the power light would blink untill i herd a click sound and the hole process would start over again. The click noise would happen every 30 seconds. I want to try to fix the problem so if any one that knows why its doing what is doing please tell me what i need to fix the problem.
  • Anonymous Jan 09, 2008
    I know what i have to do to fix mine but the reason mine blew is because i hooked up the pos to the neg and the neg then pos...maybe thats your prob....
  • edwinr Feb 07, 2008
    i have a two channel punch amp and the negative from the right channel is burnt out
  • Emran82 Jan 01, 2009
    i want kenwood amplifier (kac 819) input transistors number
    total 6 transistors four transistors is c403 and two transistors is shot ( no number ) i want number
  • Anonymous Mar 16, 2009
    Problem Solver:
Change out the fan if cant find one specifically 4 that amp get a fan from a old amp or computer and use it there easy 2 switch out or even modify if it dont fit in the amp just mount it on the out side on the air fins the problem was probably caused by 2 small of a ground or in line fuse is 2 small check spec sheet or manual but the ground should b as short as posible and a bigger wire than the positive wire make shure your fuze in amp is the right size if 2 big it will over heat and fry the amp
Posted on Apr 26, 2009
  • 45 Answers
Unknown model not working could be a bunch of things!
does the unit have power?? fuse(s) ok?? turn on voltage present(12v)?? Any leds?? Unit ever get wet?? Any lites?? smoke get out?? was it, did it get real hot??
I have worked on a few with various problems, no common problems. Some of the things I have seen; Level adj pot was smashed in, Shorted fets , + burnt gate drive resistors in the ps section + blown runs, bad connections, shorted outputs, corrosion from beer leakage, bad electrolytic caps, leaking caps ate up the copper runs, metal bars used to hold down fets and outputs came loose, parts over heated and shorted.
Open up and look around, burnt resistors, leaking caps, puffed up caps, black marks, are all helpful signs.
These amps typically use FETs in the power supply(+/- 25-50v) and regular transistors for the outputs. Test all heatsinked parts for shorts. Carefully remove metal bars holding down heatsinked parts, keep track of where the heat sink insulators go, remove pcb and inspect runs. Repair and bench test with a power supply that has an amp meter. With out any input, unit should only use a few amps after initial 5-15amps to get the PS fired up. Then test across speaker outputs for any DC voltage. Anything over 1v, (should be very close to zero) amp needs some more work.
Posted on Nov 06, 2007
Rockford fosgate amp keeps shutting down when volume is cranked
your cd player cant handle all the power, time to upgrade to a cd player with at least 80w10
Jun 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Left positive speaker input stopped working
try swapping over the rcas for instance if black is in r and red is in l then swap them so red is r and black is l
if that doesnt work try swapping the subs over to as you may have a faulty sub. if that doesnt work then check the fuses on the amp
still no joy then i would suggest taking your amp to your local car audio dealer and getting them to have a look at it
Hope this helps if so please dont forget to rate
best wishes
Upfront Audio
Apr 23, 2009 | Rockford Fosgate Punch® 450.2 Car Audio...
Rockford Fosgate Punch 401s starts then smokes
Can somebody email me the schematic for the Rockford Fosgate 401S?
Feb 04, 2009 | Rockford Fosgate Punch 401S Car Audio...
Where to take my amp for repair
Contact Rockford for factory service.
If you don't want to send it to Rockford, ask the local audio shops who they use for amp repairs. If several use the same repair shop, it's probably a good place to send your amp.
May 25, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Old rockford fosgate power 1001bd
The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
Nov 25, 2007 | Rockford Fosgate Power 1001BD Car Audio...
301x amplifier
Good luck. Rockford Fosgate does not sell or release any service parts/diagrams AT ALL. They want you to buy a new one or send it in to them to be repaired at an exhorbitant price. Also, from my experience, most RF amps are unrepaairable due to their construction design. the outputs are case soldered and cannot be removed individually. Time to upgrade.
Sep 07, 2007 | Rockford Fosgate Punch 301X Car Audio...
Orion 8004 Car Audio Amplifier Logo
324 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
