SOURCE: cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
SOURCE: Electrolux 2-in-1 Pronto does not hold charge, I
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther
model with the same specs and my PRONTO is working fine now. The battery
model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in
mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
SOURCE: The battery pack handle for
You might check with Batteries Plus.
I have had luck with several rechargeables in taking the assembly apart and finding a battery pack that would fit inside. The battery packs can be very universal...most rechargeable gadgets use universal battery packs inside their custom made "skins". All you have to do is figure out how to get the skin opened up to replace the "guts" inside.
SOURCE: Dust Buster 16.8v won't hold
What model number is this. Black and Decker does not make a 16.8 to my knowledge, so a model number would be helpful.
