Question about Electrical Supplies
Can't find manual for generac mega force generator
Can't find manual for generac mega force 6500 generator , need to change oil,  want to know what to use.
    Habit-Forming:
  • 17 Answers
Plain 30 wt is fine.
Posted on Jun 28, 2009
  • William Fouts Jun 28, 2009
    Generac has everything online..........Such as owners manuals.
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
What weight oil does a 5550 watt take?
According to Generac for there Portable generators they recommend, Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter. Here is a link to get a manual if you need one. You will need your model number.
http://www.generac.com/service-support/product-support-lookup
Jan 30, 2016 | Generac Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
I have a generac 6500 mega force, that has a 60v output on the 120v outlet and 120v on the 240v outlet, the regulator board has a blue wired that acording to the wiring diagram was to be hooked up to one...
You need to run tests on your alternator. We have made some videos to show you how to do this on our website. It is very easy!
https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
We also hold some parts for generac generators if you need them. You can purchase them on this web page:
https://www.generatorguru.com/generac/
If you need any more help, please contact our Engineers. They will be more than happy to assist you with repairing and parts supply!
https://www.generatorguru.com/ask-the-guru/
We are always happy to help!
Regards,
The Generator Guru Team
World Leading Supplier of Parts and Spares for Portable Generators
Mar 18, 2017 | Electrical Supplies
Reset change oil message on generac xp8000e
There is no way to reset it manually. It resets automatically after you run it a few hours.
Nov 03, 2012 | Generac 5606 XP Series XP8000E 12,000 Watt...
What's the mag or coiul on a generac 6500 generator 13 hp
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
Sep 30, 2012 | Generac 6500 Watt Gasoline Generator - 49...
I need toque specs for a Generac GT990. Head bolts and rod bolts.
Just happened to find a copy on-line for the Generac V-Twin GT990 Engine Service Manual.
E-Mail me : js2770@yahoo.com and I'll send you the PDF File for that. Good luck with your repair.
May 08, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Generac 6500 mega force generator lost compression
remove cylider head check the gasket the inlet and exhast valves also inspect the piston if you see no sign of damage remove the piston and check the piston rings
Mar 16, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
May 08, 2009 | Electrical Supplies
Electrical Supplies Logo
693 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
