Question about Dell Inspiron B130 Notebook
I need replace a cooler fan but I dont know how to open the computer to get to there.
  • 107 Answers
#1 priority is to disconnect all power including battery. All screws on the bottom of the laptop have a letter which indicates what they are removed for. There is no screws specifically for the fan. You just have to pull all screws and seperate the case. Make sure you keep track of where the screws go. the main thing to remember is when the case is seperate look for the shortest way to get to the fans. Typically each component has a plug. Unplug it and remove it. Try to keep track of the order things are removed. Write it down if need be. Good luck.
Posted on Jun 28, 2009
Coleman model 5645 inside fan motor not working .. how do you open the cover to get to the fan and motor
pull straight up on the cover. Remove the 4 screws that hold the fan to the heat sink. You can then remove the 2 torx screws and remove the heat sink if you need to. Clip the wires as close to the bad fan as possible so you will have enough for the new fan.
Feb 01, 2010 | Coleman Electric Cooler 40 Beverage Cooler
The outer fan dont work. where can i get a replacement ?
Check at your local computer/ Hobby Electronics parts store.
Take the fan out of the unit and to the store with you, that way they can match it to one they may have in stock.
Sep 14, 2009 | Coleman Electric Cooler 40 Beverage Cooler
CPU Fan Error
you will remove the cpu fan and cleaning the fan after insert.otherwise insert the new sutable fan.
Sep 10, 2009 | ASUS A7N8X-VM Motherboard
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Foxconn CPU fan making noise
It sounds like the fan bearing is shot, I'd recomend not using the computer until fan is replaced.
yes it is possible to replace the fan, i would recomend that you replace it with an aftermarket cooler. all you need is what kind of CPU you have, then find out what kind of socket it is, from there you can find the cooler you would like.
Jan 27, 2009 | Foxconn CPU Cooler Fan CPU Fan
Fan starts runnung fast and everything is frozen
Overheating. Try using canned air and blowing out vents. If you are comfortable with it, take the laptop apart and clean it out. If not, contact a local computer shop that can do it for you. If cleaning doesn't do it, the CPU heatsink will need reseated or the CPU will need replaced.
Jan 15, 2009 | HP (344872-001) Laptop Cooler, Cooling Fan
Toshiba celeron satellite cooler replacement
first.you can find the processor fan in some computer shop,but i dont know if they will give you.second,check the model # of the fan and check in the internet for delivery or else,you can repair the fan by replacing the dynamo of the fan with another model of fan,just anly remove the screw of the fan and try to find another model fan and replace the dynamo fan.
This kind of issue is i try with some of my customer because they cant find the same model of fan.
Sep 18, 2008 | Toshiba Satellite Laptop Cooler
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Dell Inspiron B130 Notebook Logo
104 people viewed this question
Alun Cox
