Question about Microsoft Xbox 360 Console
No picture on tv screen when i turn on my 360 plz help
Look ive had my 360 for a year and it used to work fine but now when i turn it on i can hear it but no picture comes up on my tv ive pluged it into 3 tvs and the same thing happens its hooked up properley but no picture comes up please help me
Make sure the hd switch is not turned on on the video cable that connects to the xbox, it is a small black switch
Posted on Jun 28, 2009
Hi there, when i turn on my xbox 360 i can here the audio but cant get any picture. What can I do to fix this problem?
Try this as it worked for me.
First i took off my hard drive on the 360. Then i pluged it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i pluged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wraped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. mine has been working for 3 days now with no problem i even have it hooked up using the HDTV cables in my living room.
Mar 21, 2010 | Video Game Consoles & Games
My xbox 360 wont show a picture but it has sound
This is how to fix it. So here is how you do it. First i took off my hard drive on the 360. Then i pluged it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i pluged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wraped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. i hope this will help u....pls rate...cheers...
Jan 05, 2010 | Microsoft Xbox 360 Console
I have sound,but no picture
check to see if your coords are plugged properly if so it could just be the coords might need new ones
Jul 27, 2009 | Microsoft Xbox 360 Console
Picture won't come up on my xbox 360.
When it is starting up push down y and pull the right trigger the console will reastart on default settings and u it will show the picture if this dosent work try when you hear the menu screen come up. It worked for me but now i have lines going acroos hopefully you wont have tht problem
Jun 29, 2009 | Microsoft Xbox 360 Console
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
XBOX 360
check connections.
e-mail me at B3652@live.com
May 31, 2008 | Microsoft Xbox 360 Console
Trouble!!
sounds like a loose video cable. Check your connections
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Xbox 360 console
try a different t.v it just might be the tv
Oct 30, 2007 | Microsoft Xbox 360 Console
Use the "HD Selector" on the cable that plugs into your xbox360 and make sure it is pointing to "SD" and then turn on your xbox360. This should put the console in standard definition mode and allow you to see the picture on the screen. If this doe not work, check and make sure you are using the proper inputs on your tv and selecting those inputer accordingly.
Jul 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
115 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
