DOOR SENSOR GOES OFF EACH TIME DOOR IS CLOSED
Good Afternoon Friend,
I understand that the door sensor goes off on your Frigidaire Affinity washer, model# LAFW7000LW0, when the door is shut. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: what is error code E23 for the Frigidaire Affinty
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
SOURCE: Frigidaire ATG67000FS1 (Sears) won't start.
"The control panel may in *LOCKED* mode.
Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel.
Make sure the detergent tray is fully closed too."
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: How do I start my washer....I get I hit the start
Check to see if your supply lines are turned on and that the hot and cold lines are not crossed up.
Good Morning Tim Taylor, thanks for your inquiry!
Based off the information you have provided I see your Frigidaire dishwasher is pausing multiple times before cycling. From what you have described it sounds like the possible issue could be within the door latch or sensor. If the panel is not reading that the door is closed it could be causing the dishwasher to stop and start. The sensor could also be sending false signals to the panel causing pause. You may want to seek assistance from a professional technician for proper diagnosis and repair. This will help to avoid any unnecessary part purchases. -Matt
