Question about SuperMicro SUPER P6 DGH (P6DGH-USA) Motherboard
When my power supply died, it took out the plug. However, there are THREE different power inputs to the board=> AT, ATX, and one that looks like 1/2 of an AT power input. Which is why I was asking, how do the various power connections on the board work? Perhaps the reason my other power supply failed is because it wasn't providing power through all the required inputs? Would the ATX input be a complete substitute for the AT inputs? I don't have a manual for the board, and the Supermicro site is funky at the moment.
    Genius:
  • 1,066 Answers
You have to find a vintage power supply which will support all 23 of your mobo connections
Posted on Jul 01, 2009
Not getting any video from a msi 880gma-e55 integrated video motherboard
This may sound simple, but make sure the monitor is set to correct input. Many are auto detect, but you never really know.
You could also check BIOS for onboard video. Disable if you have an add-on video card. Enable if you don't
Reseat the video card if it an add-on.
Jan 08, 2013 | MSI Computers & Internet
Think has a short in it!!
you can also use an ATX PSU by put a wire between green and black to switch the power on and put your died psu's wire into black and yellow plug (+ on yellow - on black)
Dec 06, 2012 | Tripp Lite Computers & Internet
Can not get computer to power back up no lights on front o rear just little light on mother board have dell 8400
Bad Power Supply, sscorbett.
Usually you have enough power to light LED lights, (Like the harddrive activity LED light for add-in cards, that you see on the motherboard), and spin fans, but Not enough power to turn the Processor on.
Dell Support >Dimension 8400 > Service Manual
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
Technical Overview > System Board Components
http://support.dell.com/support/edocs/systems/dim8400/SM/techov.htm#wp1052739
harddrive activity light for add-in cards (SCSI LED)
The Dimension 8400 comes with an ATX style of Power Supply, that has a maximum rated Wattage of 250 Watts.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Your Power Supply just has enough power to light that LED light.
Weak voltage power rail.
Replace the Power Supply.
[ There are three power rails inside that SMPS.
Switched-Mode Power Supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail ]
The ATX form factor for a Power Supply refers to the size, and shape of the case, for one.
Approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall.
The ATX power supply case in the Dimension 8400 however, is shorter in length.
It is 4 inches Long. (Depth)
Not an advertisement for the website, nor manufacturer.
Reference for the case size, and power cables needed,
http://www.cputopia.com/hp-400w-dell-dimension-8400.html
Scroll down to see the connectors of the various power cables needed.
You may have a Power Supply with these dimensions, and needed power cables, in an unused computer.
Perhaps someone has upgraded to a better computer, and has an unused computer that you can temporarily borrow the Power Supply for a test unit.
Make sure it has at least 250 Watts (Maximum rated wattage), plus,
1) 20-pin ATX main power cable. (Or a 20 + 4-pin ATX main power cable)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[ 20 + 4-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4 ]
2) 4-pin ATX +12 Volt power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Plus the various power cables needed for the Harddrive, optical drive/s, and computer case fan/s, if it/they do not connect to the motherboard.
Oct 21, 2010 | Dell Dimension 8400 power supply ** FREE...
I am looking at a Dell Dimension 4550 PC for a friend and it won't boot up...i push the power button on and there is an almost orange/greenish light on the power button... no beeps no diagnostic lights are...
Bad Power Supply. Weak voltage power rail.
[There are three main voltages produced by the Dimension 4550's Power Supply.
1) 3.3 Volts
2) 5 Volts
3) 12 Volts ]
The Power On button LED functions as a diagnostic light also.
Dell Support > Dimension 4550 > Service Manual,
http://support.dell.com/support/edocs/systems/dim4550/
Left-click on Solving Problems, then click on Power Problems
The Power Supply is just an ATX form factor version. The common Power Supply form factor used in MANY desktop computers.
(ATX form factor for a Power Supply refers to the size, and shape of the Power Supply's case.
Approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall)
HOWEVER, (Not shouting), there is an area of concern, should you try a Power Supply you may have available for a test, or purchase one.
It involves the wiring of the 20-pin ATX main power cable. More specifically the power cable's connector.
To explain view the standard wiring, set for a 20-pin ATX main power cable's connector,
Looking at the photo to the far right, observe the color code of the wires, going down into the socket holes of the connector.
Look at the Lock tab on the side of the connector. This will help you orient the color code of the wires, and their placement in the socket holes, to the chart below the photos.
The connector on the end of the 20-pin ATX main power cable, is a Male connector.
Where the wires go into the connector, is the Back of the connector.
In the middle photo you can see the Front of the connector.
The wires going down into the ATX main power cable's connector, end in a female metal terminal.
The connector on the motherboard, (Shown in the photo to the Left), has Pins.
The metal female terminals go over the Pins.
The pins are numbered. The color code of the wires match up to the pins.
This is shown in the chart.
Now look at Dell Support > Dimension 4550 > Technical Overview > DC Power Connectors >
DC Power Connector P1
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101897
The illustration may not be accurate. You'll have to compare since you have the computer, and Power Supply in front of you.
For a time period Dell was a Proprietary manufacturer.
Meaning they wanted THEIR parts used on THEIR computers, and ONLY THEIR parts.
They had the motherboard manufacturers make motherboards according to their specs.
One of the specifications was that the pins would be CHANGED around, in the motherboard connector for the ATX main power cable.
They also had Power Supply manufacturers make the ATX power cable to their specifications.
This means if a user bought an aftermarket Power Supply, the color code of the wires in the ATX main power cable would Not match.
Many users did buy an aftermarket Power Supply, and installed it.
Burnt motherboards, fried Processors, and graphics cards, resulted.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
Black wires are Ground wires.
Guess what happens when you plug a 12 Volt wire into where a 3.3 Volt, or 5 Volt, or Ground wire is supposed to Be?
POOF!
My suggestion would be to look for a Power Supply that is an ATX form factor, is KNOWN to be good, and is compatible, for a test unit.
You, or someone you know may have upgraded to a better computer, and you may be able to borrow the Power Supply for a test unit.
Compatible:
Has the Correct power cables.
1) 20-pin ATX main power cable, OR a 20/24-pin ATX main power cable.
(20-pin connector that has an additional connector with 4 pins. Just use the 20-pin)
2) 4-pin ATX +12 Volt power cable. (Also referred to as P4 MB, and P4 ATX 12V)
(Power for the Processor)
3) Enough standard 4-pin Peripheral power cables.
(Misnomered as Molex)
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(Power for the IDE Harddrive, and Optical drive/s)
Also:
You can change the power wires around in the ATX main power cable's connector.
Change them around, in an aftermarket Power Supply's ATX main power cable's connector.
Want to know how post in a Comment.
Oct 09, 2010 | Dell Dimension 4550 PC Desktop
Hpw do you replace the power source on a gateway MFATXPNT ESX 500S.
How do you know the power supply is the problem?
What issues are you experiencing?
Have you done any trouble shooting first? It could be a bad hard drive.
If you should need to replace the power supply first you need to get a replacement power supply for a gateway MFATXPNT ESX 500S - 300 watt power supply you can get here.
The next step is to unplug the computer from the wall > remove the case side access panel > ground yourself with an Anti-Static wrist strap cord so you don't fry *********** board electronics from static electricity discharge which can cost you a lot more to replace > now disconnect the plugs from the power supply wire harness, it may help to count the connections and mark them with a piece of tape or draw a diagram so you don't forget which loose cables should get reconnected to the new power supply. There will be at least one that connects directly to a plug on the mother board, DO NOT put tape there. > Next remove the screws which mount mount the power supply to the metal frame and slide out the power supply > slide the new power supply in the same way the other other was removed (note top from bottom) and then screw back to frame and reattach the cables > close the case > remove your grounded wrist band > plug computer back into wall and start the computer.
Congratulations, you have just replaced your power supply and ready to go.
IMPORTANT: Do not switch the power output selector switch on the power supply. Usually a recessed re switch which will adjust for european vs. US power input conversion.
Additional Resources and Tutorials
Step by Step Video Tutorial to Replace Power Supply
With pictures, step by step
Diagnosing ATX Power Supply Failure with Diagram
How to diagnose and replace a failed pc power supply
Hope you find my resources and information useful and rank or review it accordingly.
Jan 12, 2010 | Gateway GT5220 PC Desktop
I am looking for a wiring diagram for my emachine front power switch
Power Supply Types
There are two basic types of power supplies. There are AT power supplies, which are older and in older computers, and ATX power supplies, which you will find in virtually every new computer you can buy.
There are two fundamental differences between AT and ATX power supplies. First, the switch mechanism is different. AT power supplies use a normal on-off switch, which directly turns the power supply on or off.
ATX power supplies use a momentary switch which does not directly control the power. Instead, the switch signals the motherboard, which performs one of three actions:
  • If the computer is off, the power supply is turned on (which turns the computer on)
  • If the computer is on, the computer goes into power-saving mode (standby)
  • If the switch is held for more than 4 seconds, the power is cut and the computer turns off.
Because of this difference, ATX power supplies are better for projects that require the second power supply to turn on automatically when the computer is turned on.
The second difference is in the motherboard connector: AT power supplies provide two 6-pin connectors (figure 1), which are easy to insert backwards. The ATX connector is a single 20-pin connector that only plugs in one way (figure 2).
Figures 1 and 2: The difference between AT (left) and ATX (right) motherboard connectors.
Both power supplies provide two types connectors for plugging devices into. These connectors are called Molex connectors, and they come in two sizes (see figure 3 and 4). A power supply will generally have a few of each size.
Figures 3 and 4: Large (left) and small (right) Molex connectors.
There is no difference between the two sizes other than the size itself. Both sizes provide the same amount of power to whatever device is plugged into it (12V and 5V). The small Molex connectors are generally used only for floppy drives. Large Molex connectors power hard drives, CD/DVD drives, and many fans and lights as well.
Note: You can purchase large and small Y-adapters if you run out of Molex connectors. Be careful when using the Y-adapters however, because if your power supply does not have enough power for all the devices attached (especially true for older, lower-wattage supplies), you can damage it.
Dec 03, 2009 | E-Machines eMachines Desktop PC
Computer won't boot up
Have you tried a higher rated ATX power supply? Preferably a 350w.
Apr 22, 2009 | ASUS SiS Chipset TUSI-M Motherboard
Problems on PCCHIPS M701G Motherboard
connect your three pin socket in your power plug
Jan 12, 2009 | PC Chips M701G V1.1 Motherboard
P4t533c asus motherboard died (RIP)
check the power supply...use anther outlet to plug the power cord..
Aug 27, 2008 | ASUS Computers & Internet
DOA
Sounds like you need a new power supply for your computer.
Jul 19, 2008 | Antec SP450 450W SmartPower ATX 2.0 20/24...
SuperMicro SUPER P6 DGH (P6DGH-USA) Motherboard Logo
63 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
