Question about Port Incorporated ATX-7765U Mini-Server Midtower Case (Beige) w/350W Power&Front USB Port
I am needing assistance install 5.25" drives int he external bays due to the slide rail system. Can you please provide instruction or documentation explaining how to?
  • 4 more comments
  • crash_the_gr Jun 28, 2009
    I did receive them, however do the slide in from the back of the cage/inside the case or from the front of the cage/outside the case?
    When I try to slide them in, they seem to catch either way and won't slide in and I am not wanting to break anything, and they will not even fit from outside of the case in witht he front panel on, does this need to be removed?
    I have a cell phone camera, I will send what I can with it. Are there instructions to remove the front of the case? I can get both side panels off, but cannot find how to take the front panel off.
    I think I got it, it took some fiddling with on my end, but I found the clips hidden in the case. If not I will send you the photos for further help
    It did work, I had to remove the front panel, and it was well hidden on how to do so.
    Thanks for your help.
    Very helpful
  • 13,433 Answers
Hi
please post the brand and model of the machine and all other detail you have about it / found from it.
Then I will be able to sort it out, Thank you.
Posted on Jun 28, 2009
  • 5 more comments
  • Ekse Jun 28, 2009
    Thanks, looking into it.
  • Ekse Jun 28, 2009
    I see - its a slide rail system. with the product you should have received rails that you can easily attach to the 5.25" drives, which will hold the drives in place on the slots, meant for easy installation and removal without screws.
    Put the rails on the drives, and slide them in, they snap into place, seen these before. Did you receive anything with the case?
  • Ekse Jun 28, 2009
    Generally you slide them in from the front of the case, make sure they are set right way, the pushable / moving parts on the outside and the flat -- Straight end going inside. leaving the moving / movable kind of release lever outside the case or on the front.
    Wish I had a picture for you - Seems like the front panel will need to come off.
  • Ekse Jun 28, 2009
    do you have a digital camera? can you email me a pictures from the case the rails inside the case and from the ones that attaches to the drives?
    email is nikoht@gmail.com
  • Ekse Jun 28, 2009
    generally few clips or screws holding the font panel in place from inside.
    Please email me from now on and I will respond as soon as possible when I'm available again. (I'm on different timezone....)
  • Ekse Jun 28, 2009
    sure
  • Ekse Jun 28, 2009
    your welcome, please accept the soluion.
D1776 asko dishwasher upper basket ball bearing asssembly falling apart
Hello, welcome to fixya
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
push down on the bumper as shown
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here )
The trick now is to install the balls into the holders first
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Again, good luck :)
May 16, 2011 | Asko D1776 Built-in Dishwasher
Hard disk not found message coming while installing windows server 2003 on HP Proliant ML150 G5 server system.pls help me
Save any critical or important files. Even if this is an secondary hard drive installation.
Turn off the power and unplug the PC from the outlet. Also, unplug all external connections to the Windows PC. Be sure to touch something metal to ground the user. Static electrical shocks can damage a PC.
Open the PC housing and determine the placement of the hard drive. Generally computers come with a latch that, when pressed, opens the housing. Make certain the space necessary for the hard drive is available. Usually the drive bays are in the front of the PC near the CD or DVD drives.
Make sure the IDE jumpers are set correctly. If the hard drive is the primary drive then set the jumpers to "Master" mode. If the hard drive is the secondary drive then set the jumpers to "Slave" mode. Please consult the hard drive's manual for the proper jumper setting for each mode. Another possibility--if there are two hard drive, set both drives to "Cable select" mode and the Windows PC will choose which one to make "Master" and "Slave."
5
Mount the hard drive in the available internal slot. The drive is sometimes mounted with four screws to the drive bay. Some internal drives have a rail that slides into the open bay. Look at the other devices to determine which mounting option is available in the specific computer.
6
Connect the hard drive cables to the Windows PC. Connect the power supply connector to the available cable. Next, connect the data cable to the available connector. The internal data cable usually has a red stripe to make identification easier.
7
Close the housing and reconnect the external power supply. Plug the external cables back into the computer and reconnect to the power supply.
8
Configure the BIOS. The BIOS (Basic Input/Output System) is accessible during computer start-up. To access the BIOS consult the computer manual to find out with which key press during start-up. Most often, the key is F8. Once in the BIOS change the hard drive setting to "Auto detect." When finished, exit the BIOS and allow the start-up to continue.
9
Format and partition the Windows PC hard drive. Select "Start" from the operating system menu. Choose "Control panel" from the start menu. Next click on "Administrative tools". From the administrative tools menu choose the "Computer management" icon and finally "Disk management." Choose the new hard drive and right click. Select "New partition" from the right click menu. Follow the on-screen option to partition and format the drive the drive.
10
Restart the computer and check the hard drive to ensure it is operating properly.
Feb 23, 2011 | HP ProLiant ML150 G5 Server - 1 x Xeon...
I have a WD3200ME external driver..it works on vista but when i changed my OS to windows 7, it cannot be read..then i go back to windows vista thinking it could be read but the same thing happen.. it says...
If your WD external drive is not recognized, it can be caused by one of the following problems:
  1. Your driver may be corrupted. The symptoms of this problem can vary - The majority of the time however, the drive may request a driver, or will not appear as a connected device. You will need to contact Microsoft or your System Manufacturer for assistance in resolving this issue, as we are unable to provide assistance in diagnosing your OS.
  2. Important Information: It has been reported to us that some users have been able to resolve this issue using the SFC Command in a Command Prompt. When contacting Microsoft or your System Manufactuer, providing them with this information may assist in resolving this issue. Please note that WD Technical Support cannot assist with the usage of this command line program, and is not responsible for any damage to your system or data it may cause.
  3. Your drive may be damaged or have failed. A good test for this is to try the drive in another system. If the issue continues to occur, than this is most likely the case. For assistance replacing your drive under warranty see Answer ID 8: How can I replace a product under warranty?.
  4. In some cases you may need to install a drive in order for your drive to be recognized. Check the table below to see if your model drive requires a driver to be installed besides the one that is included in your Operating System. Please note that this table includes any drive that has a driver for any reason.In most cases the drivers listed are not required for the drive to function, but add some additional funcationality that the OS supplied driver cannot provide. If an OS is not listed in either column, your WD external drive is not supported on that OS. If a driver is available, select the OS in the list to go to the download page for that driver.
Microsoft Windows 64-bit Operating Systems working with Western Digital hard drives trnsp.gif Question Do Western Digital hard drives work with Microsoft Windows 64-bit Operating Systems? trnsp.gif Answer External Hard Drives
Our external hard drives should work with 64-bit operating systems. But, again, there are some things you need to keep in mind:
  • Drivers for most Western Digital USB and FireWire external hard drives are already included in all 32-bit and 64-bit Microsoft Windows operating systems.
  • When Western Digital drives are connected to the computer, the operating system should automatically recognize that there is a new device and install the drivers for that device to function on that system.
  • Western Digital does not provide any generic drivers for our external hard drives in the event that the system drivers do not load properly.
  • In the event that one of our drives does not install on your operating system, here are some simple troubleshooting tips you can follow:
    1. Plug the power adapter directly into the wall to make sure the drive is getting enough power.
    2. Change the USB/Firewire cable to make sure that the cables aren't bad.
    3. Try the drive on another PC. If the drive installs on that PC, and you can see it in the Windows Explorer, then you know that the drive is good.
    4. If it doesn't show up in Windows Explorer, but does show up in Disk Management, then the drivers are installed and you most likely have a format or partition issue. In which case, please see:
    5. If the drive doesn't show up in either Windows Explorer or Disk Management, then the drive should be replaced.
  • If the drive shows up on another PC, then there may be driver issues with the operating system where it's not installing. You will need to contact Microsoft Support at http://support.microsoft.com for further help troubleshooting your operating system.
Dec 21, 2010 | Computers & Internet
Need to remove hard drive
his document provides instructions for the removal and replacement of the hard drive for the R3000, R3100, R3200, R3300, ZV5000 and ZV5200 series notebook PCs.
Use the video as a guide while following the written instructions below.
To view the video press the Play button on the player control bar below the video.
To stop the video press the Pause button on the player control bar below the video.
To restart the video press the Rewind button on the player control bar below the video.
NOTE:Flash Player from Macromedia is required to view this video. Visit the Macromedia website (in English) to download and install Flash Player.
Step 1 - Remove the battery
Slide and hold the battery release latch to the unlock position.
Use your finger to lift the battery up and out.
Step 2 - Remove the hard disk drive
Remove the two Phillips-head screws that secure the hard disk drive to the base enclosure.
Lift the inside edge of the hard disk drive to unseat the hard disk drive connector from the system board.
Remove the four Phillips-head screws that secure the hard disk drive to the hard disk drive bracket.
Remove the hard disk drive from the hard disk drive bracket.
Pull the hard disk drive out of the bay.
Place the hard disk drive in a static dissipative bag.
Dec 05, 2010 | HP Pavilion ze4300 Notebook
How to copy photos from PC to external hard drive?
How to Copy Files to an ExternalHard Drive
External hard drives provide great storage space for movies, music, picturesand other documents you want to keep safe over time. The drives generally comewith either USB 2.0 or Firewire connectors, so they also offer reliable datatransfers at high rates of speed. Setting the drives up is usually astraightforward process, and copying files to them from your computer is a snap.
1. Set up your external hard drive according to its instructions. The two majorsteps in setting one up are connecting it to your computer and plugging it intoan external power source. 2. Install any drivers that camewith your drive so your operating system will recognize it. If the drivers areoutdated, download and install new ones from the manufacturer's website. 3. Open the "MyComputer" panel. You'll see both your regular hard drive (the C: drive)and the external hard drive listed. 4. Double-click the externalhard drive's icon to open its window. 5. Drag and drop any files youwish to copy to the external drive into this window. 6. Right-click the "SafelyRemove Hardware" icon in the System Tray and eject the drive once you'vefinished copying your files. Read more: How to CopyFiles to an External Hard Drive ' eHow.com
Nov 10, 2010 | Computers & Internet
My laptop which is now 3 yrs old is CONSTANTLY rebooting. It acts as if it is going to fully load Windows XP, but then starts the reboot phase all over again. Is there anything I can do to stop this? I am...
Hi Good day!! try to run your windows in Safemode, to run in safemode, press f8 continuously while booting your pc. Option will appear after pressing f8 choose safemode. your pc will start in safemode. after that do some scanning and then reboot your pc see if your windows will start normally. if not work please relpy to me and i will assist you more thanks!!!
Don't forget to vote Thanks!!!
Oct 28, 2010 | Computers & Internet
I have Ricoh 2016 copier with scanning facility. It used to scan documentsand send it to email as pdf before but after I upgraded my pc I lost the settings and do not know how to get it fixed
Please note, this isn't a solution, but an assistance.
Well, it seems no one is so familiar with Ricoh email scanning setup. Me too, have not much experience with it, honestly i've tried this only once and was successful following the instructions. First you'll need to login to the Web Image Server and then configure it. At this point, you'll need the ip addresses of the server, dns server, client and host name. Then next you'll need to configure the SMTP authentication via Web Image Monitor, hre you'll have to provide email address (administrator's), smtp server name/ip address and port number. Then Pop and Smtp Configuration, Ldap Settings, and so...... on.... it'd would take more than 2 hours to write down all the instructions here. I am afraid whether you can follow the instructions since it's a little technical setting up this (similar to outlook etc..). Well let me provide you the document I use to refer last time.. click here to read the document. You can start from Page No.6, and follow the step by step instructions, it's a thorough instructions with screenshots for easier reference.
Please, I am only assisting you, I don't need payment for this, if you can, just hit the thumbs for me. That'd be very much appreciated.
Good luck,
Thanks for using FixYa.
Jun 18, 2010 | Computers & Internet
How do you install a hard drive to a dell optiplex sx270
This computer only has one space for a 2.5" hard drive (IDE ATA100). Unplug all external cords from the computer (including the power cord) and press the power button (this grounds the system board). Remove the mounting plate and cable cover if these are attached. Place the unit on its side with the back connectors towards you (power supply to the left) and slide the release button towards the right. The hard drive door should open. Ground yourself by touching unpainted metal on the case. Rotate the door up and remove the data cable from the drive (carefully). Raise the release tab (on the opposite side from the data cable) and pull the drive up and away from the door. If you need to, remove the sled from the old hard drive (4 screws, 2 on each side) and attach the sled to the new drive. (If the new drive came with a sled, skip this step.) Slide the new drive onto the drive door. Attach the data cable carefully to avoid bending the pins (just the ribbon section is used, the other 4 pins are left bare). Slide the drive into the drive bay and lower the door to lock it into place. Replace the cord cover and mounting plate if in use and connect all of the external cables. Plug the network cable into the wall jack, router, or modem before connecting it to the computer. Follow the directions that came with the drive for any software installation. Reboot the computer, partition and logically format the hard drive. See the OS documentation for this step. Test the hard drive by running the Dell Diagnostics, http://support.dell.com/support/edocs/systems/opsx270/en/ug/adtshoot.htm#1172888 . Install the OS for your system.
If the chassis alert comes on at the next reboot, reset it (contact IT if there is a password on the BIOS).
I hope this helps.
Apr 26, 2010 | Dell OptiPlex SX270 PC Desktop
I recently purchased a kwikset jda-9760718-002
You can download them from kwikset here. Just choose your version of the lever, select Installation & Troubleshooting instructions from the search list, and scroll down to the .pdf document file listed in the next window.
But that lever is pretty standard, and there are also some kwikset installation directions here
You can use some pretty generic instructions if you just google "install lockset"., that may have some useful pointers.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | Kwikset Sheridan Handle Set
I want to replace the hard drive. I have the new hard drive but I am unsure how to procede
The 13 Easy Steps to Installing a Primary Hard Drive Compiled By Our Editors Believe it or not, all it takes is less than a half-an-hour and a Phillips screwdriver to install your primary IDE hard drive into your desktop PC. Simply follow this illustrated 13-step guide and it’s mission accomplished! Please make sure you consult your user manual and other manufacturer-provided documentation while you complete the installation - you will need to refer to instructions at certain points in the operation.
image1.jpg 1. The first step is obvious! Power down your PC! And for safety measures make sure you have unplugged all your power cords.
image2.jpg 2. Next locate all the screws and/or clamps that hold the computer case and/or panels together.. image3.jpg 3. Now it's time to gain access to the interior of the computer case. Simply remove the case or the panels that hold it together.
image4.jpg 4. If your PC happens to have a removable hard drive bracket, now is the time to remove it! It’s specially designed to be removed without hassles, and its absence will make this simple installation project even easier.
image5.jpg 5. Now it's time to leaf through the documentation that came with your hard drive, along with any included diagrams, for instructions on how to set the jumpers on the drive. If you're the type of person who hates to read the instructions, bury your impulse to neglect this crucial step. If your system has but a single drive connected to the cable, use the “Cable Select” option; this will suffice in most cases when there is only one drive. If another drive exists it will be connected to the same IDE cable, using the “Master” setting.
image6.jpg 6. You're almost halfway done! Wasn't that easy. Now the fun begins! Slide your hard drive into the drive bay, then fasten it down. Some cases employ a system in which slide rails mount onto the drive for easy insertion and removal from the drive bay.
image7.jpg 7. Remember that removable drive bay bracket that you removed in Step 4? Now it's time to return it to the inside of the case.
image8.jpg 8. You will find that most ATA/66 and ATA/100 IDE cables have either a blue connector or a connector labeled “System Board.” In the likely case that this applies to your PC, plug this blue connector into either the IDE0 (Primary) or IDE1 (Secondary) connector on the motherboard. The primary connector is color-coded blue, in most circumstances, to indicate that it should be used for a hard drive. Usually, you can insert the cables in but one way. However, if the cable is not keyed for one-way insertion, make sure that the red stripe on the IDE cable matches up to “Pin 1” on the motherboard.
image9.jpg 9. Attach your connector that is located the farthest distance on the ribbon cable to the hard drive. Usually this connector is either black or labeled “Primary.” Make sure you place the red stripe on the cable at pin 1 of the hard drive’s connector. Note: Most drives are keyed to allow the cable to fit in only one specific way.
image10.jpg 10. Now locate a 4-pin power connector from the power supply. Simply attach it to the hard drive’s power connector. You're almost done!
image11.jpg 11. Next, replace your computer case or panel.
image12.jpg 12. Tighten any screws or clamps to fasten down the case or panel.
image13.jpg 13. Finally, reattach your computer’s power supplies.
Voila! You’re done. Your hard drive should now be installed and ready for operation. Now your computer BIOS must detect the hard drive the next time you power up your PC. Double-check your PC or motherboard user manual for instructions on how to detect a new hard drive. Perhaps you may need to change some of the parameters in BIOS to detect the hard drive on the controller. You must also format the drive before it can be used with the operating system. Again, consult your manufacturer-supplied documentation for additional information.
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Top Port Incorporated Computers & Internet Experts
David Payne
David Payne
Are you a Port Incorporated Computer and Internet Expert? Answer questions, earn points and help others
