Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wayne dalton classic drive 3018, door goes 90% down then goes back up. Works fine manually, chain, spring, and cable all look good. Opener light blinks for about 30 seconds. Not the obstruction sensor. What to do?
Wayne dalton classic drive squeaks and binds then stops
Posted on Aug 09, 2009
    President:
  • 3,197 Answers
Double check your door sensors. All your symptoms point to them.
Posted on Jul 02, 2009
How do I replace cables on a wayne Dalton 3018?
You don't. The springs are inside the torquemaster and if you don't know what you are doing, you can get severely hurt. Call a Wayne Dalton dealer and let the pro's do it. Chances are your springs are broken anyway if the cables are off. Or better yet, call any other dealer and let them do a Torsion conversion and get rid of that torquemaster so you can work on it next time.
Feb 20, 2015 | Building Materials
How many times do I have to replace circuit board on my opener? So far this will be the fourth now I also have to replace the sensors .This thing is only 7 yrs. old . I have 2 chamberlin openers on ot
Not much to go on , but two things spring to mind.. 1. After your next replacements , put silica gel packets in the circuit house, and sensors too if poss .. Then seal properly with silicone sealant. 2. Add in a Fuse and Earth to your circuit properly. This will remove any stray voltages from blowing your circuitry.. Lightning can kill circuits, so a lightning protector between fusebox and circuit would also be a good idea.. If the circuit is not in an appropriate housing , your circuit issue will persist. Best of luck.
Nov 19, 2017 | Wayne-Dalton Wayne Dalton Classic Drive...
Wayne dalton 3018
Release the garage door from the opener and open the door by hand, if it is vey heavy you may have a broke spring inside the torsion bar above the header, check then to see if the opener goes through the complete cycle O K with the door not attached. If you don't have a broken spring you may need to increase the up force on the opener head.
Oct 23, 2013 | Building Materials
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Don't have instructions for my wayne dalton door need spring instructions
Wayne- Dalton uses 4 different types of counter balance springs-extension, torsion, torquemaster 1, and torquemaster 2. I would need this information for a good answer. A photo would help a lot too. Thanks BB
May 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Wanye dalton door opener modal 3018. goes up 1 foot and stops
Check your door springs. Usually just over the door and can be seen when the door is closed. A broken spring is the most common cause of this problem.
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,313 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
