Looking for a Ruud 10 SEER condenser cabinet to replace
I'm looking for a Ruud 10 SEER condenser cabinet to replace damaged stock enclosure. Do you know of one?
    Sergeant:
  • 340 Answers
Nope ive been down that road nothing new try one of your local contractors they may have some thing used for cheap. Tom
Posted on Jun 28, 2009
I have a 12 year old ruud a/c system for a 1500 square foot house. I can not read the tag on the unit. looking for the pressures, type of freon and what the vent temperature should be. I can make out a...
Ruud back then had a label tag that would fade out or fall off, the ref is R-22, if you check the supply air temp. and then check to return air temp. the difference is plus or minus 20 degrees (18 to 20pluss ) your good, its called delta t. 20 degrees is good. The 10 is the SEER rating.
Jul 05, 2011 | Heating & Cooling
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
I am looking for a Compressor for a Ruud Achiever 10 Seer 1.5 Tons. Does anyone know where I can purchase one? Thank you!
Hello, you should be able to purchase that compressor at any heating and cooling store in your area. As long as you have the model and serial number they will be able to help you out.
Apr 28, 2011 | Heating & Cooling
I'm looking for a Compressor for a Ruud Achiever 10 Seer 1.5 Tons. Does anyone know where I can purchase one? Thank you!
Craigslist or EBAY depends . You would be better advised to purchase a new unit on-line usually the whole unit is about the same as a compressor and not nearly as much work.
I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
Aug 18, 2009 | Carrier 38CKC042 Air Conditioner
Does my 10-seer have a 10 year compressor warranty?
If you take all the numbers off the compressor and condesning unit and call an authorized RUUD parts dealer in your area, they should be able to verify your inquiry.
Unless there was a special circumstance, most compressor warranties are 5 years, unless the compressor was replaced during the 5 year period, in which case you should get 5 more years assuming the service was performed by an authorized service company.
May 19, 2009 | Ruud Matching Split Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud uamc-048jaz
What do you need to know? That is a 4 ton 12 seer straight cool system, with 11 kw heat strip. You may go to ari.org to search perfomance data.
Dec 03, 2007 | Ruud Central System Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
