Question about Kodak EasyShare DX4530 Digital Camera
Dial hard to move
I have the Kodak EasyShare DX4530 Digital Camera. It has become very hard to move the dial on the top of the camera. At the moment, I cannot get it to move at all. It is set in the off position right now. Is there some way to fix this, or is it shot? Thanks!
Re: Dial hard to move
I had same problem.I got a new camera but wife likes this one.Decided I would try to fix.there are 9 very small phillips screws around sides and on the bottom of case .you need very small jewlers type screw driver.Some are longer tha others so draw a picture so you can get them all back in correct places.after removing all screws spread the body at the bottom top has small pivot connectors that will open when body is ****.the front and back are now connected by two small cables ,these donot have to be disconnected.the dial on top is made up of two disks and a small spring held together by another small screw .remove screw and look for any thing that is binding ,mine was a piece of worn plastic .I removed and saw how the pieces went back together.I added alittle grease to spring sides reassembled camera put back batteries and mem.card had to reset date ,but now back working like new .Hope this helps.
Posted on Mar 22, 2008
0 characters
3 Points
Menu button doesn't work on kodak easyshare dx4530
Perform a power resetting and check the operation.
Jun 23, 2012 | Kodak EasyShare DX4530 Digital Camera
The battery door on my Kodak EasyShare DX4530 zoom digital camera will not stay closed. It is possible to replace the door?
You can buy the replacement part from
so I would assume replacement is possible.
Jun 20, 2011 | Kodak EasyShare DX4530 Digital Camera
The problem of my kodak easyshare c513 digital camera is if i used it in daytime cannot captured the object,all i can see is like light of the sun...
did you try changing the settings on the dial on the top right of the camera? the dial is for different settings for different types of pictures, you would need to set the camera for daytime pics, sounds like it is set up for nighttime.
Jan 26, 2011 | Kodak EasyShare C513 Digital Camera
How do you set the apeture on a Kodak Easyshare DX4530 camera?
1 In any Still mode, press the Menu button.
2 Press to highlight Exposure Compensation , then press the OK
3 Press to select the Exposure
Compensation setting.
 If pictures are too light, decrease the
 If pictures are too dark, increase the
4 Press the OK button to accept the change.
5 Press the Menu button to exit the menu.
6 Use the camera screen to frame your
subject. Press the Shutter button half-way
to set the focus, then continue pressing
completely down to take the picture.
This setting remains until you change the
Mode dial or turn off the camera.
here is the link for the manual if the details are not clear
Oct 03, 2010 | Kodak EasyShare DX4530 Digital Camera
Faulty dial switch?
Go to a good electrical component store like The Source and buy a can of Switch Contact Cleaner and spray it into the dial making sure you remove the batteries first. Then give the dial half a dozen turns each way. Leave it for 30 minutes and then re-install the battery.
Sometimes you need to move your grip on the camera, so your fingers are not near the dial when shooting.
Nov 28, 2009 | Kodak EasyShare DX4530 Digital Camera
I checked to see if there was firmware available for free download. Unfortunantly not. The alternative is a KODAK repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
Mode dial on my Kodak DX6490 camera is hard to turn!
dissmantle the back case (watch for 1 hidden screw under rubber covers), lift plate on back of lcd screen, remove screw on back of dial, clean where it sits on both sides (most probably from a liquid spill...tea, coffee...) , apply some lube with a cottonbud ore a bit of tisue and rebuild.
hope this helps
Apr 04, 2009 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare Z730 mode dial
Does the "unlock" button depress? When my dial seemed to freeze, or turn very hard, I lightly coated a small piece of newspaper with petroleum jelly (both sides) and slid it all around under the dial. This lubricated the plastic and made it turn freely. Good luck!
Jun 27, 2008 | Kodak EasyShare Z730 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
51 people viewed this question
Top Kodak Digital Cameras Experts
Are you a Kodak Digital Camera Expert? Answer questions, earn points and help others
