Question about Senco Tools & Hardware - Others
When the 2in 18 gauge nail enters the wood it turns in the wood and comes out the side of the wood,
    New Friend:
  • 131 Answers
That is actually the nail failing. If you try shooting any 2in. 18ga. nail into something hard like Maple or even red oak, the nail will bend. It will typically follow the grain. So Go to at least a 16 ga. nail for hardwoods.
Posted on Jul 07, 2009
My new Central Pneumatic Model 68019 spits out 18 gauge 2" nails fine. However, it punches a divot into the surface of whatever I am nailing. It looks like the metal "tongue" which rams the nail out, is...
Some nail guns need an optional soft nose fitting in order to produce a flush finish without which the nail will be countersunk and ready for filling or suitable only for rough work.
Nov 13, 2017 | Air Tools & Compressors
My brand new DC608 18 gauge nailer jams every time on the 2nd nail.
Per your addendum I would have first told you to check that you are using the proper guage nails. Second you should make sure you are loading the nails in the lowest channel in the magazine so they are at the bottom of the magazine. If you load them into the top of the magazine they have more time to go off course before they get into the wood.
May 29, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
How do you determine what to set the psi for door trim and baseboards?
Your compressor has an air preasure ajustment , that will allow your to set where you will be comfortable. Turn it till you get the setting for your particular job. Use a piece of scrap wood to check nail set. I hope that I have been of service. GOOD LUCK.
Sep 25, 2011 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Does the campbell hausfeld model sb504000 2 inch nailer/stapler need an external air to get started?
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
Aug 11, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
I am trying to obtain 18 gauge brad nails for a clarke air nail gun ,can i use any type of straight 18 gauge brad or do clarke make brads for their own tools
you should not have any problem with using any other brand of nail .18 gauge brad nail are pretty much the same in all brands.
Mar 30, 2011 | Air Tools & Compressors
I have difficulty with regular jams regardless of brad length. Thoughts?
Depending on type of work/wood the finer the nail, results in increased jams. Eighteen gauge and finer experience more jams than say 15 gauge. Fine gauge nails also suffer from square cut tip. I believe that if the nails were pointed (like Senco nails ) they would more likely drive true. Jaming can be decreased by selecting the correct nailer for particular work. Dimentional lumber and hardwoods tend to increase problems compared to quality plywood or non wood trim materials. If you experience jaming with any type of wood then time to look at driver for possible problem. Check driver for bent or worn tip. Driver blade can be dressed square on grinder. Some drivers have a slight angle/taper ground into tip on the side that faces the rails. This taper continues up the blade about 1/2 inch. The taper will prevent the driver from hitting the second nail. On really hard woods, try drilling a fine pilot hole to produce best results. Good luck
Mar 09, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
My Bostitch SB 2in1 nailer will only on occation nail all the way into the wood. For the most part the nail will bend over before it goes in, which damages the wood. I spend more time tying to pull out...
I ran into this problem many times. Don`t use the Bostitch brand nails. Use the generic or other name brand. You`ll notice the generic one`s heads are just a little bigger and the driver blade won`t run down the side of the nail!
Thanks,
Jeff
Jan 05, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
Tools & Hardware - Others Logo
88 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
Matt Olenzek
Matt Olenzek
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
