Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
    Scholar:
  • 106 Answers
Unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Posted on Jun 28, 2009
ASUS m2n68-am se2 and graphic card's problem
Sounds like the PCI slot is no longer working.
Jan 10, 2013 | ASUS M2N68-AM SE2 Motherboard
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Hi.I have a ASUS M2N68-AM SE2 Motherboard with AMD Athlon 64 X2 6000+ Processor.Whenever I boot,it says that the CPU is not supported.I have updated my BIOS to the latest version.Still doesn't help...The...
What bios are you using? Usually that error message can be disregarded since you can manually set the CPU clock, voltage, etc in the bios and it should work. Also, this might mean that the bios currently loaded is corrupted/broke. But since you did update the bios, to what version?
Also, are you using the integrated graphics for gaming? If so, that would not suffice for heavy gaming at high resolution. You should be using a dedicated video card for that.
As for system performance, how slow is it? What is your OS as well? can you try to download cpuid, and see if your processor is detected properly in windows.
Apr 27, 2011 | ASUS M2N68-AM SE2 Motherboard
I use an AMD M2N68 SE2 motherboard.I bough an NVIDIA 9500GT graphics card lately.Now my display will go out after a few minutes..
Hi. This is usually an indication of overheating. Make sure the fan on the graphics card is not blocked. Clean out any dust in your system and ensure adequate air flow across the CPU and the graphics card.
Dec 06, 2010 | ASUS M2N68-AM SE2 Motherboard
I need the drivers for amd sempron motherboard M2N68-AM SE2. could anyone share me the download link plz. thanks in advance.
I have found them for you
go to asus.com
http://support.asus.com/download/download.aspx?SLanguage=en-us
this will have the complete chipset, I have checked and your model still has updates including the bios
Nov 15, 2010 | ASUS M2N68AM SE2 MicroATX Motherboard AMD...
No beep, no display in new asus m2n68-am se2 motherboard
Try booting the system with a bootable and well memory stick and probably check the power switch if it send any signal to the board while pressing it.
May 07, 2010 | ASUS M2N68-AM SE2 MicroATX Motherboard &...
Asus M2N68 says CPU is not supported but works ok
if the voteage do not match the qvl watt for watt you can damage board or cpu
Mar 31, 2010 | ASUS M2N68-AM SE2 Motherboard
I just bought a asus M2N68-AM SE2 mob and a amd athlon 64x2 6000 processor and it comes up this model does not suport this cpu. others have same problem. I just want to no what cpu will work. what are...
Supports: AM2+ Quad-Core CPU/AM2 CPU and 45nm Phenom? II CPU Here is the complete list; your CPU is not listed. http://usa.asus.com/product.aspx?P_ID=2UWzsrOiRbMPGYpw
Oct 16, 2009 | ASUS M2N68-AM SE2 Motherboard
ASUS M2N68-AM SE2 Motherboard having problems installing an inno3d 8600gt graphics card. motherboard doesnt seem to pick up the card. when plugged in monitor stays on standby. also downloaded the latest...
I would first check BIOS and disable Onboard video (if applicable) and then make sure that graphics port is set for PCI-e and not PCI or pci-e 1x or something.
Check that first. And make sure that card is all the way plugged in. You won't believe how many people don't plug it in all the way.
Brian
Jul 08, 2009 | ASUS M2N68-AM SE2 Motherboard
Though i have mother-board which has inbuilt Graphic of 256MB i am not able to play games with high graphics, i have Asus-M2N68-AM, with AMD-LE1640, and 2GB Ram, Could u please solve the problem
The built in graphics on motherboards are ok for drawing programs and such but not for high speed animation and graphics that games require. You need to get a add on card for your system either, be sure to get a card with a graphics set that is supported in your game.
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jun 30, 2009 | AMD Athlon 64 LE-1640 Processor...
Computers & Internet Logo
498 people viewed this question
Alun Cox
David Payne
David Payne
