Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Light fixture smell like it running too rich
My grandparents moved to this home in 1998 thare this lamp for the bastment stairs that everytime you turn it on you can smell overheating wiring thay change the bulb out to a lower watt bulb but the smell
is still thare when it turn on something tell me the wiring
on the lamp has gone faulty and overheats when the lamp is on i dont
doubt it sins the lamp is pretty old
  • 115 Answers
Change out fixture
Posted on Jul 07, 2009
I need help to find a Bakelite light fixture for an Art Deco lamp, tall free standing
Fixya is unable to suggest sources for Bakelite light fixtures.
May 22, 2018 | Home
Electric smell, lamp assembly screw wont fit
If you removed the screws, they should be reinserted in the same fashion as when they were removed. One thing to remember, over heating can change the sockets overall condition and using it could lead to a fire in the long run. It sounds like the contact between the lamp (Bulb) and the fixtures base has a gap. Electrical sparks (arcing) will smell and thus is a danger calling out, shut me down.
Feb 16, 2018 | ASK Proxima C160 Multimedia Projector
Suzuki aerio
is running rich. that cutting out is called misfire.
in this case, rich caused misfiring.
Does the CEL lamp come on? Check engine lamp.
misfire is complex. (caused my many a thing and needs careful
diagnosis by a technician)
May 13, 2013 | 2002 Suzuki Aerio
I'm interested in an inside elevator for my grandparents
Are you referring to an actual elevator or the stairs lift?
Elevators are much more expensive than the stairs lifts. Of course they have to be wide enough with the right curve.
Please take a look at this site:
http://www.daytonaelevator.com/
Apr 28, 2013 | Medical
Testing photo cell
These devices typically require a minute or two to change state from ON to OFF when the the threshold of light and darkness is reached. Place black electrical tape over the sensor and allow a minute for it to turn the light on. Make sure that no light shines into the sensor or that the sensor can not see light in the night time.
Lastly, double check instructions and wiring. White should be connected to BOTH the neutral incoming power AND the light fixture's white wire(s). Most times, black is 120V source, and red is the switched 120V out to the fixture.
If it isn't working, make sure the lamps are good. This photocell is suitable for use with compact fluorescent lamps, fluorescent lamps and other fixtures that use ballasts and transformers as long as they do not require more than 840 VA.
Dec 29, 2012 | Carlon Home Products Wired Photo Cell Post...
Check engine light, smells like eggs and no power
Your exhaust converters are over heating thus the
sulfur or egg smell
Your car is running to rich,too much gas being used
You have a MIL Lamp ON
Stop using it until resolved or engine & converter
damage may occur
Check for codes & go from there & get back if you like
Nov 19, 2012 | 2000 Lincoln LS
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
Fluorescent lights will not come on. There is power to the ballest.
Power to the ballast is good. The power you checked is known as the primary power. The secondary power from the ballast (transformer), should be around 600 volts. This 600 volts is what vaporizes the gas in the fluorescent lamp. Go to home depot and buy a magnetic field tester (we call it a thumper) It has a shirt pocket clip on it. Do not insert the thumper in the fixture lamp sockets, just put it in front of one of the light fixture sockets. It should beep and the light on the magnetic field tester (thumper) should come on if you have a magnetic field in the light fixture socket. This means that the light fixture ballast secondary is working. No beep and no light from the magnetic field tester (thumper) means your ballast is bad. Ballast are dangerous to replace. Have an electrician replace it. Your life is not worth losing over saving a few dollars.
Jan 06, 2011 | Lithonia Lighting White Finish 48" Wide...
Extra blue wire what is it for
48" light fixtures come in single lamp, two lamps, and four lamps. The ballast must match the supply voltage and the amount of lamps the fixture has.
Dec 23, 2010 | Lithonia Lighting White Finish 48" Wide...
Heating & Cooling Logo
74 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
