SOURCE: sharp AR 250 with error code H5-01
SHARP
AR250
H5-01
Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
SOURCE: error code h5-01
H5-01 Refers to an exit sensor problem, open the left side door and check the exit flag and or sensor. But yeah to reset H codes go into simulations by pressing (Program, Interrupt, Clear, Interrupt) Once in there hit 14, Start. Then it will ask you if you want to execute or something in that manner. Hope that helps
SOURCE: how to remove h5-01 error code on a sharp arm550n
This is either:
10 continuous POD1, POD2 or PPD2 JAM
OR
Other models this indicates too many fuser jams. The fuser error reset
code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on.
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
