Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My salt water sytem stopped working so we diconnected it from the pool what could be the problem
    Problem Solver:
  • 9 Answers
"stopped working" does that mean stopped producing chlorine? Remove the cell and check the cleanliness of the plates; there should be absolutely nothing on any of the plates period! Make, model and manufacturer would aid in diagnosing this problem
Posted on Jun 28, 2009
I have an Intex Ultra frame 18x48 with the salt water system, I haven't added salt in a while and keep getting a high salt alert and I add water frequently because of the evaporation (which is well water)....
When water evaporates, it leaves the salt behind. Depending on your well water, it may also already contain salt - adding yet more salt to your pool each time you top up...
Perhaps try emptying your pool (all or partially) & starting again - don't think the old trick of sticking a potato into an over-salted soup to absorb the excess (& removing it before serving, of course) will work on a pool!
Aug 06, 2013 | Intex Automatic Salt Water System for ...
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
WE ADDED FOUR 40 LB BAGS TO 18 X48 EASY SET POOL AND STARTED UP THE SALT WATER CHLORINATOR THE NEXT DAY . THE CODE FOR HIGH SALT CAME UP. WHAT SHOULD I DO? ALSO WHEN THE CODES POP UP DOES THE CHLORINATOR...
Start buy draining 20% of your water and adding fresh.
Filter normal for about 12 hours.
Now test your salt PPM
You can get a salt test kit at any pool supply
you want your salt ppm to be as close to 3000 as possible
any lower than 2700 and you will not produce enough sanitizer and over 3500 can produce high salt code, just taste bad, and ruin your cells in the unit
As for not working, yes the unit will not function properly with any code that comes up
Jun 14, 2011 | Intex Automatic Salt Water System for ...
I connected my saltwater sytem from intex for above ground pool, ran it for the appropriate time for the gallons of water which was 3 hours and now my water is all brown, why did this happen and how do I...
Sounds like you have iron in your water (well water perhaps?). You can get some stuff (sorry, don't remember what it is) from a pool place that will take care of that. It drove me nuts the first time I did it - drained the pool and started over thinking it was brown algae!
Jun 28, 2010 | Intex Automatic Salt Water System for ...
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Code 91
91 means Low Salt. I have seen this occur if the salt level is actually too low as well as when the plates have a large amount of white crystals on them. If your plates look clean (I use a pressure washer to clean them), check the salt level using salt test strips you can get at a pool supply store.
Jul 02, 2009 | Intex Automatic Salt Water System for ...
No LED
In the manual it states that depending on what type of salt you use, you may have a yellowish tint to the water. What kind of water are you using for the pool? If it's well water you may even more of a discoloration to the water. I'd call Intex directly and see about getting the unit fixed, even if you didn't buy it direct from them they should still be able to help you. Good luck!
Jun 09, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
198 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
