Question about Bottom Line Fishin' Buddy 1101 GPS Receiver
My fish finder doesn't show bottom consistantly and often doesn't show depth. Also, it seems to have stopped marking fish. The last three or four times out with it, it hasn't marked a single fish. And we've been catching fish so I know they're there.
3 Suggested Answers
SOURCE: Bottom Line Tournament 1101
You can get a manual free by calling 1-800-456-5432. The Bottom Line Tournament 1101 is made by Hummingbird. I got the number from a sport shop here in Roseburg, OR. Called it and they're sending me the manual free! Good luck. -- Gary
Posted on Sep 05, 2009
  • 4 Answers
SOURCE: I lost my graph/depth of the bottom of the lake?
just buy a new 1
Posted on Apr 12, 2010
Doesn't work on fast flowing river
Many depth finders don't work when the transducer sees a little turbulence. My only suggestion is to try different locations for the transducer, trying to guess where there will be the least turbulence beneath it. This is easy if your transducer is mounted inside the hull and reads through the hull. Not so easy if it is a through-hull mount. Be sure it is mounted correctly to the hull if it is mounted inside the hull.
Dec 03, 2017 | Lowrance HDS5x Fishfinders
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
Bottom Line Fishin'Buddy II Fish/Depth Finder user guide/manual?
i have an older fishin buddy 2 bottom line sidefinder i need a manual, a bracket that holds it to the boat and the battery holder / handle i hope you can help me with this my email dave2_3@yahoo.com
May 09, 2009 | Boating
Erratic depth and does not indiacte any fish
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to sensitivity set to manual then go up one on the menu and set it to 95 – 97 this will clear up the rapid change now set zoom to manual. Your back and running.
Mar 31, 2009 | Eagle Cuda 242 Portable Fishfinder
Depth dosnt work on egle fish mark 320
MY depth finder blinks 0.0 depth all the time
May 11, 2008 | Eagle FishElite 320 GPS Receiver
Bottom Line Fishin' Buddy 1101 GPS Receiver Logo
143 people viewed this question
Top Bottom Line GPS Experts
Will Halftowaite
Are you a Bottom Line GPS Expert? Answer questions, earn points and help others
