The green power button on my daughters Nabi Jr is stuck inside the Nabi Jr. I kept having to push it harder and harder to get it to turn on, and the last time I pressed it in it got stuck inside and won't pop back out. I don't have a warranty on it and its more than a year old. Is it mpossable to fix it?
I know this is an old post, but our button just broke (May 2017), and it WAS the switch behind the button. I assumed it had broken the solder joint, but it was actually the tactile switch button that had broken off. I replaced the switch to where it's working again. Ours was a Nabi Dreamtab, but I soundslike the same issue.
I called Nabi at 855-ASK-NABI, and they sent me a $40 coupon for any mattel item, and said the new dreamtab is at Walmart for $69... That's not a bad fix... They also said the motherboard manufacturer is no longer in business, so they could not recommend repair.
However, I'm OCD and don't want a good electronic piece to go to waste. So I fixed it by buying a new tactile switch for the motherboard, and replaced it myself (had a friend do the soldering). Now it works great. Took me FOREVER to find the replacement part, so I thought I would share to those who are motivated to FIX their Dreamtab.
Steps to fix it, if you care:
NOTE: For the next part, I REALLY recommend a technical person who knows soldering to perform the actions...Take it to one of those phone repair shops. They can probably do it if paid by the hour.
I hope this helps.
2. Remove 6 screws from the back lego looking plate thing.
No it isn\'t that hard a little finickally unless you\'ve broken the button inside in that case it will be a mongrel and near impos to do it sorry
