Question about Garden
Chainsaw oiler leaks oil out case and no oil on chain
    Brigadier General:
  • 4,088 Answers
Take the bar and chain off--run the engine--the oiler port from the case should discharge some oil. If none, you have trouble with the oil pump or the tubes to and from it. The oil tank may be leaking at the tank opening for the pickup tube. If oil appears at the oiler port, then there may be dirt/blockage within the oil passages in the bar end. Clean with compressed air.
Posted on Jul 04, 2009
Automatic oiler problem since date of purchase. Remedy?
No found recall for this. link below not your exact model, may help on repair of oiler
Chainsaw chain oiler repair
Jan 16, 2016 | Makita UC3530A 14" Electric Chain Saw
Oil leak mcculloch electramac em250 ?
You have a cracked tank, or busted chain oiler. Will have to take apart to view the chain oiler , and check if oil is puddling just under the oil tank. There is some epoxy sealers, or gas tank stop leak material that can possibly repair the busted or leaking oil tank.
Jul 19, 2014 | McCulloch Garden
Stihl saw leaking chain oil?
Chainsaws can become messy even if the oiler is working correctly. Check the oil level frequently during a cutting session. If frequent refills are necessary, the oiler may be defective
Jun 02, 2013 | Garden
Echo cs 3450 oiler does pump oil to chain bar, leaks along side case
not familiar with that model but check that the oil passage from the pump to the bar is clear and not broken or cracked
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 19, 2013 | Garden
Poulan-Pro 295 leaks excessive bar-chain oil
It's a seal somewhere either on the reservoir, or the 'feed' to the bar.
But in the short term, if you must use it, the simplest way of stopping the leak, is to not store it with any oil in it, until you locate the source of the leak.
That should help, but I'll wish you good luck never the less ;)
& plz don't forget to rate, thankyou :)
Jul 18, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw leaks chain oil when not in use
You might try loosing the oil cap on the chain oiler filler cap to release any preasure that might have built up during use and is forcing oil out as it sits. It sounds like a simple fix but it might just work.
May 06, 2009 | Garden
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Leaks oil in case from chain oiler
hi
check the oil line,the oil hose has to be at the right place.
regards savumihai71
Dec 02, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
726 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
