Why does my mic record at normal volume, but game volume is too quiet?
I use a razer usb heat set. whichever I select to be in track 1 (mic or speakers) it records the loudest. However, my mic will only record in track 1, so the game audio recording in track 2 is extremely quiet. Why is this how can I stop it and what can I do to fix this or set the volume at which each track is recorded?
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
1. Did you select Left channel only in Audacity for the track you're recording?
2. Maybe it's a defective mic. Try it on another computer/software/USB cable/USB port and if it still doesn't work get Samson to replace it.
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools:
Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1
Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Depending on the DAW software, you can record just his track at that time. Mixing can be done later with multi-track software, such as Cubase or ProTools.
There should be an extra device in the volume controls under your OS's control panel. That extra device will be your USB mic. Select this device for recording. Monitor the input recording levels BEFORE actually recording to check for clipping. When you are adjusted correctly, you should have plenty of volume, and no clipping. From there, you can modify that waveform like any other track.
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:
select a voice track to record into
make sure the Track Info window is open (blue i button in lower right region of screen)
at the bottom of the Track Info window you will find Input Source:
Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
This model appears to only have a mic input. Which I have on other models used as a aux input. You may have to turn off the mic boost under "Sounds and Audio Devices" And select the Voice (tab). Then click on the Volume button for the mic. Now sliders will appear and that Advanced tab should be the boost toggle.
Here are some instructions relayed from someone who was able to fix a similar problme with help from Samson tech support:
The C01U is a WAV device. Therefore, adjusting the slider for your default MIC input level on the volume control applet does not adjust the gain on the C01U. You access the actual volume control for the C01U as follows:
Start, Settings, Control Panel, Sounds and Audio Devices
Click on Audio tab.
Under "Sound Recording", insure that Default Device is selected as Samson C01U.
Once Samson C01U is selected as Default Recording Device, click on the Volume button just below the name. A new window will pop up, with a vertical slider. This window will be labelled "WAVE IN", however it actually does control the MIC volume for the C01U.
The key here seems to be that the USB device that represents the Microphone input (as far as Windows is concerned) is not a traditional microphone, but (as mentioned above) a WAV-IN device.
