Question about Panasonic NN-S951WF Microwave Oven
Looking for parts
Is there a source for internal parts for this microwave? Looking for the circuit board component for the the keypad. There are two associated with the keypad.
  • Panasonic Master
  • 9,098 Answers
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa:
If you prefer, you can Panasonic parts via
Posted on Nov 26, 2007
  • 473 Answers
GE cafe convection microwave 9CEB1590SS only heats up with convection heating element.
Can be part of the power supply or the controller board. Best to take the unit in for service. You would need the spare parts to try, the service manual, and the proper voltever to make the necessary verifications.
Jan 04, 2018 | GE Microwave Ovens
Code "F3" is highlighted on Key Panel
F3 usually means a problem with the control panel. There may be a corroded component or a power surge damaged the unit. Sometimes a little water will get into the keypad and cause the problem.
First try unplugging the unit for ten minutes. That may reset error code. (For built-in units, you can try flipping the circuit breaker to off or removing the trim to reach the power cord.)
If that fails, unplug the microwave again. You can remove the vent by unscrewing the top screws. Open the door to get the vent free. Then unscrew another screw to tip the keypad down (push up at the bottom of the panel). Disconnect the wires from the circuit board and remove the screws. Remove the circuit board and the shield behind it. Check over all of the pieces for dirt or signs of corrosion. (Clean gently.) Let everything dry (or use a hairdryer to dry all sides of the components). Then replace the parts in the reverse order. Plug in the microwave and check for the error.
If that fails, replace the control panel. One source for parts is .
I hope this helps. It may be cheaper to replace the microwave.
Jul 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Mistral microwave MUMW23SS has no heat, light comes on, turntable operates OK, tested the megatron and reading 0.4 ohms, tested the internal fuse this is OK any suggestions
The keypad control board is more than likely the problem, if microwave is less than 7 years old the inverter board has been a source of trouble from time to time. When you consider parts cost it will approach if not exceed the value of a new microwave oven.
Apr 07, 2012 | Microwave Ovens
Unplug microwave, remove top, go to the right where keypad is located, follow the wire to the circuit board, look for a silver rectangular capacitor and short a screwdriver over the 2 points to remove any remainder of voltage. There should a small fuse clipped in near by, replace with same current rating, assemble before testing, carries lethal voltages when turned on.
Mar 09, 2012 | Emerson Microwave Ovens
The letters "SE" is on
Hi, there are two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing is to clean the connection. So first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket.then use a spirit to clean the exposed copper connections. Put every thing back to place then try it
Apr 07, 2011 | Kenmore 62622 Microwave Oven
I have a sharp microwave sometimes it works for 10 or 20 seconds and then stops with error ee2, other times it works fine. Today it did the same but stopped with error ee1!
This sounds like a keypad problem, sometimes a short developes in the keypad controller causing all kinds of intermittent problems, on the back is the microprocessor circuit board which controls vital areas of the microwave oven. The cost to repair will be high and consideration should given to looking at a replacement.
Feb 17, 2011 | Microwave Ovens
I've got a model: JES1036PWH02.....when I plugged the unit in the internal light came on, the screen showed all eights and then in a few seconds shows a "PF" and NONE of the buttons work? How...
The keypad controller is defective, behind it there is the microprocessor ic mounted on a board with several other parts. The whole keypad and circuit board must be replaced, and the cost just for the part will run more than a new microwave.
Feb 06, 2011 | GE Microwave Ovens
I need a circuit board for a MH7130XEZ-1
The printed circuit board (PCB) was part number 4359413 then was superseded by part number 8172053.
It looks like it may be no longer available or at least not through usual sources, but sites like and show they can provide it for about $172 to $195.
But depending on the problem, we may be able to repair it with our $39.95 repair service. We repair hundreds on microwave control boards every year.
And we've repaired these.
Jul 02, 2010 | GE JES1289SK Microwave Oven
Control panel not working
Your membrane keypad is failing.
Actually this job on this model can be completed by a do-it-yourselfer (you or a friend) pretty easily and at around $50 or so. Here's how:
You can order the control panel frame assembly, which comes with a new keypad. It's part # 383EW5A231S and it runs $42.73 plus shipping form the Sears parts site.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Plus see this diagram at the Sears site.
Then you would disconnect the keypad strip from the circuit board as shown in the photo below.
After that, you take your circuit board out of the old frame (being careful not to drop or bump it) and put it in the new frame and put it all back together.
If you want to avoid taking out the board, you can order the complete controller assembly instead (frame with keypad and circuit board installed) part # 4781W1M432A for $87.02 plus shipping.
If you're still intimidated, at least watch our video. It's really pretty simple.
Jun 29, 2009 | Kenmore 80412 Microwave Oven
Panasonic NN-S951WF Microwave Oven Logo
97 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
