Question about Plumbing
My bathtub drain is American Standard circa 1927. The tub stopper is actuated by turning a knob connected to a linkage connected to a rod, connected to a yoke which threads onto a sleeved pipe which travels up and down in the drain pipe. I want to know if the sleeved pipe is perforated in order to allow the water to drain when such openings align with the tee connection from the tub, or if the sleeve lifts completely above the tee in order to allow the water to drain. I am trying to figure out if this trap is part of my slow drain problem.
    Problem Solver:
  • 17 Answers
Your close to figuring it out,
I would guess you have a hair clog in the trap. they have inexpensive plastic rods (like a long zip tie) with serrated edges on it to capture the hair. Home Depot or Lowe's or Menards will have these
Posted on Jul 05, 2009
How does the lift and turn stopper come out so we can clean plugged drain?
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Mar 12, 2011 | Maax Soprano II: One-Piece Shower Module...
    About a year ago I installed an American Standard Cadet lavatory faucet with the Speedconnect drain. When I fill the sink with water it leaks out very slowly. I have not had any success in repairing this...
    Try adjusting linkage under sink,squeeze metal piece and pull off to adjust to different hole setting,you can fine tune with small screw on chrome rod,so you can pull stopper down tighter
    Jan 30, 2011 | Home
    I have an American Standard tub, that is about 82 years old. It was just re-glazed, and I am trying to replace the mechanism that allows you to stop water to fill the tub up, or to open the drain when...
    There should be athreaded adjustment rod in the linkage that you set up or down to make the stopper seat in the tee that connects the overflow line to the drain on th bottom of the tub. Hope this helps you. Thanks
    Jan 03, 2011 | Home
    Tub drain wont stay open
    If this is a trip lever waste type of drain it can be adjusted, Remove the 2 screws that hold the adjusting lever, this will allow you to remove the stopper. Clean the stopper of hair and sludge and replace. This will usually fix the problem. If not then adjust the linkage for the stopper.
    Nov 23, 2009 | American Standard Scala Bathtub Only ...
    Drain stopper in the bathtub has come off how do you reinstall when the stopper turns with a knob on the tub
    the stopper just sits in the hole. When you turn the knob the cable operates the piece that raises and lowers the drain plug. The weight of it and the suction of the water is what seals it....provided the o-ring is good on the plug.
    Oct 12, 2009 | Home
    Slow water drain from Royal whirlpool tub. How to
    under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
    Jul 29, 2009 | Home
    The tub/water stopper...how do you take that off to unclog hair in the drain?
    The overflow drain / stopper lever has 2 screws holding it in place, place a rag over the drain and remove the 2 screws. then remove the drain assembly, it should slide right out. You can now clean the assembly, you may still need a piece of wire to fish the hair out.
    Jul 24, 2009 | American Standard 2771.018WC.222 Cadet 5'...
    How do I remove an American Standard (or Delta?) pop-up drain?
    Remove the lift rod and lift up the stopper.
    The lift rod is under the sink and one end goes to the lift rod and the other end goes into he base of the plug.
    Jul 05, 2009 | American Standard Princeton 2393.202.011...
    American standard bath drain problem
    The stoper assembly has linkage and a plumb bob aparatus
    Step 1 remove the 2 screws that hold the chrome overflow cover,
    Step 2 you will see a wire connected to the up and sown handle
    Step 3 you should be able to fish out the linkage which will have a bumb bob attached
    mae sure this is all connected if not reattach if you do not see the blumb bob reach your fingers in and grab the wire
    Step 4 inspect the linkage the first link is about 3 inches from chrome cove, second is about 8 inches down and final is at the bob itself bob is pointed and slides in by gravity
    If this all looks ok then fish it down , put chrome cover on and move lever up and down ( you should see the stopper mve up and down
    Step 5 If stopper is not in just insrt in drain hole and move the lver flow lever up and down and drain should work sometimes the stoper does not go up or down far enough there could be an adjustment on the linkage to reduce or increase the length of the linkage
    Good Luck
    Dec 28, 2008 | American Standard Evolution 1599.205.020...
    Plumbing Logo
    340 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
