Question about RCA D52W19 52" Rear Projection Television
Turned off by itself and then I smelled sulfur.
I have a 1996 RCA 60 inch TV, model # P60756BA, serial # 641280431, service # P60756BALG2, chassis # PTK178L2C OK TV turned off by itself, then I smell sulfur, TV would not turn back on and every time I try I smell sulfur. Green lite does come on. Can someone point me in the right direction?? I have unplugged it for now. Worried about the smell.
  • 1030 Answers
SOURCE: will not come on
well .. the smell is not good.. that usally idcates high voltage arching... 90 percent chance its what is called a flyback. and when they go the horizontal out put goes...not a difficult repair for technician.. but you have to get right parts
Posted on Dec 10, 2007
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
SOURCE: i have a 60 inch crt RCA that will not turn on the
my tv wont turn off
Posted on Sep 28, 2009
SD Tech
  • 14553 Answers
SOURCE: Have an RCA 60
It is the 169 chassis-over 300 different models used it and are different-answer something for me--does it have a GREEN power light that comes on for a second and goes off?
I know this set well and to be honest hated working on them--Let me know about the power light and I will tell you what I know.
At one point in time this was a very good set--I do understand about paying a lot to get it fixed and having it bad again.
I am here to help people and I bet I know more about this set than almost anyone else here.
SD TECH
Posted on Dec 15, 2009
  • 1039 Answers
SOURCE: My RCA 52 inch rear
Replaced the high voltage transformer. It is arching.
Posted on Mar 21, 2011
I'm looking for a tv tuner RCA projection tv model no. P60756BA
shopjimmy.com the board in your photo is the switch mode power supply
Jul 23, 2014 | RCA Tuner/input Board 30900192
Tv shuts itself off or on on its own.
Hi - definitely needs a service call. I believe it is a problem with a specific integrated circuit. Not user servicable. I have the 20 inch version of this set and it was one of their better models, more sophisticated chassis, etc. Might be worth fixing if you like the set.
Feb 28, 2011 | RCA TruFlat 27F520T 27" TV
Hi there, I have a question on an RCA 60" rear projection (P60756BA) The unit started smelling one night so we unplugged it when I tried it out again the sides of the TV on the picture were "bowing" or...
It is a convergence problem and the board is getting hot if you can smell it. Fire is the risk of running this TV. To properly repair this all 3 boards should be replaced simultaneously as recommended by the maker. You are looking at $300 +labour and a lot of syncing with the right tools here. Cheaper to have it fixed than play around with a TV that is difficult to get boards syncronised without the correct tools and diagrams You have to decide what is the decision fix or discard
Please rate my hel[++++Thanks for using FIXYA
Jun 25, 2010 | Televison & Video
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
My Philips 60 inch rear projection TV model
Mute the volume and listen at the rear of the unit. You should be able to hear a fan running since these have hot-spots that require some kind of air movment to keep them from overheating. There are protective circuits that will shut down the power supply once a critical temperature is reached.
The second possibility is the power supply itself; these sophisticated units are very energy efficient but have components in them that age and lose their function over time. The main supply should be fairly easy to spot; it will have larger components on it, some cylindrical (capacitors), others block-like.
If the fan is running and it is still shutting down, this supply may need repair or replacement. Look for a part number on the board and inquire at the manufacturer's service center about those possibilities. Have your model & serial numbers of the set available too.
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
TV fried from power surge
What is the chassis number? It should be located on the rear of the set. Have to have the chassis number before I can help
Mar 03, 2008 | RCA P60920BL 60" Rear Projection...
Rca ctc195 big screen tv trouble
You are likely to have a high voltage transformer bad which is common problem for ctc 195 RCA If you look into the back of the tv it is the white square looking thing about 3 inches across by 3 inches with the large red wire coming from it and going back into the set. Must have original RCA part and must be unsoldered and solder in new one. Not to be done by the untrained. Average cost to come out and repair is $250 to $300. depending on the repairman (Note: the chassis is in a complete wooded chipcore box that will come out with quarter inch nutdriver and unplug two plugs at the top of the box The box or chassis can be taken to the repair shop leaving the screen at your home saving a service call. Hope this helps
Dec 30, 2007 | RCA P52937 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
172 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
