There is no error code. I just need to know how to raise and lower the temperature of the refrigerator.
SOURCE: kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
SOURCE: Kenmore Elite refrigerator won't stop making ice
sometimes when you pull the shelf in and out, it will bind on the shut off arm and cause it to "pull out" of the i/m module. the arm has to be put back into the back of the module. you can take the i/m out of the freezer or just use a mirror and look for the place the arm goes. it looks like a 1/4", round, white plastic slot. the arm just pushes into the white piece and thats what causes the i/m to shut off when full or when the arm is lifted up.
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
