Question about GE Profile Spacemaker Over-the-Range Microwave
Ge profile microwave makes noise when running but does not cook the food
  • 417 Answers
Hi, sounds like she went but you can disassemble and see what happened, look for chars on the outer case, sometimes they arc from hi output to case use leater gloves to reposition the high output wires away from the outer case, theres an inline fuse in there, or on motherboard , like a car, get the exact replacement, check cooling fan for obstructions . be careful , ges are the best, worth repairing
j
Posted on Jun 28, 2009
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
JVM 1790sk01
Cook using microwaves or convection in this stylish microwave oven that allows your food to be flavorful beautifully browned and cooked quickly .now your microwive didn't work .you should take it to fix .
home light bulbs
May 03, 2012 | GE Profile Spacemaker Over-the-Range...
My3yr old GE profile microwave doesn't warm up
from what you are discribing , I would be looking at the high voltage transformer
Feb 13, 2010 | GE Profile Over-the-Range Microwave
Spacemaker (JVM1871SK) 1800 Microwave doesn't microwave
Remove the case and see if you can localize the smell. Likely suspects are a shorted high voltage diode (replace) or a shorted stirrer bearing (replace stirrer)--a fan-like device located within the sheet metal waveguide near where the microwaves enter the cooking cavity. Make sure to have a cup of cold water in the cooking cavity when looking for problems. The problem could also be the high voltage transformer or the high voltage capacitor, but these are more rare problems. There are no radiation problems with the case off, but there are high voltages associated with the magnetron and it's power supply.
Oct 08, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker II Microwave won't beep
hi,
The control board may need to be replaced, check your records to see if the unit is still in warranty, if it is call for repair. If it's not and you’re handy, you can find the part online and replace it yourself, just make sure you unplug it before you work on it. Please contact me if you need help.
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
206 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
