Question about Exercise & Fitness
Cant find an adaptor,sears on back order for months
It is made by technical Devices
AC ADPTOR
Model No. DV-1250
Input: 120 VAC 60Hz 12W
Output: 12VDC 500mA
  • 49 Answers
Go to nearest electronic store get a universal adaptor comes with different settings and diff plugs. Or find the manufac web page and other dealers universal adap cheaper too but has to be 500 ma or higher depending on what is it for.
Posted on Jun 28, 2009
Is the AC adaptor OEM Model Number AD-121ANDT? Input 120VAC, 60Hz 25W, Output: 12VDC 1A, Plug-In Class 2?
According to the picture on the Amazon website of the OEM brand that is the specs for that transformer.
Nov 08, 2016 | The Audio Players & Recorders
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
I just got a ultrak Kc552bcn ccd camera on the back has a conection for a 24 V AC, my question is that i have a radio shack ac adaptor input:120V AC 60hz, output 18/24 VAC 100ma,can i use this adapter and...
First, you have to find out the current requirement for that 24 VAC input. Just any old adapter won't do. With regard to polarity, most adapters code the positive output with a line of some color.
Oct 31, 2013 | Ultrak Kc552bcn Ccd Cctv Color Security...
I need a new adapter for my portable cordless recharger Battery for cars boats ect. The one i have is model no;D12-70 input;120V 60Hz 12W output; 12VdC 700mA
Hi Jodie,
Here is a website that carries the kit for boats, etc.: http://www.centurytool.net/Vector_Battery_Chargers_s/2464.htm
This website carries other accessories: http://www.centurytool.net/Vector_Battery_Chargers_s/2464.htm
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 21, 2011 | JUMP START SYSTEM
My Nesspresso machine is a U.S. Version machine and uses 120VAC 60 hertz power input, and it is used on a private aircraft using a 120 VAC 60 hertz power converter. When plugged in an turned on the small...
I don't know if you already solved the problem, but did you check what the maximum output power of your aircraft is? The nespresso machine needs about 1250 Watts, which is a lot of power. A vacuum cleaner or microwave use less power than that (maybe between 800 - 1000 Watts). Maybe that difference is the reason. Also, you mentioned that you converted from 220V 50Hz to 120V 60Hz. I think you only converted the voltage, a frequency converter would cost thousands of dollars.
Jan 18, 2011 | Nespresso Citizmilk C120
DVE AC ADAPTOR, model :NO.: DV-91A, INPUT :
You dont need an exact replacement for your router to work, just check on radio shack for generic adaptors with the same specifications, they would work fine, make sure voltage is the same as well as wattage...thats all that matters, and obviously input being 120vac, Hope this helps..
Oct 25, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Lifestyler c760 power supply values/specs
it is made by technical Devices
AC ADPTOR Model No. DV-1250
Output: 12VDC 500mA
Apr 21, 2009 | Exercise & Fitness
What ac adaptor does the canon 5000F require (New Zealand)?
Specification:
Input :100-240VAC (50-60Hz)
Output : 12Vdc 1.25~1.5A
those are the specs on it.... any adaptor with 12 volts dc. output of at least 1.25 amps will work you can find them at most electronic supply stores... walmart probably even sells them
Mar 16, 2009 | Canon CanoScan 5000F Flatbed Scanner
Cpq321mm microinv. desk top speaker system . I need to know what voltage the power supply is as i have put mine in a box of 35 different ones
AC Adaptor Model RGA57122000 Input 120 VAC, output 12 VAC 2000mA. I have this very set and just now took the info off the unit.
Dec 29, 2008 | Micro Innovations CPQ321MM Computer...
Using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Jun 07, 2008 | Cameras
Exercise & Fitness Logo
83 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
