Question about Kohler K-15160-7 Coralais single-control pullout spray kitchen sink faucet
The pullout spout leaks
The re seems to be a leak from the pullot spray
  • 39 Answers
Pull out the spray part and tighten the nut around the hose or take it loose and replace the washer
Posted on Jun 29, 2009
How can you remove a 7560w spray head?
  • Take out the plug button on the front side of the faucet handle and loosen the set screw with your Allen wrench, then pull off the handle. Remove the domed cap underneath the handle by unscrewing it.
  • Take off the entire spout by removing the mounting hardware under the base and lifting the spout up and off the faucet. The hose will be attached underneath the counter. Once you unscrew the connector, the spray head can be removed.
Sep 09, 2014 | Moen 7560W Extensa Glacier Lever Handle...
How do l fix our leaky kitchen faucet
If its leaking from the base of the spout where its attached to the body, its most likely the O rings that need replacing. The spout body could also be leaking as the metal is quite thin and can develop pin holes under the bottom face of the spout. To determine it that's the problem, turn the water on, place your hand under the spout body, you should not get any water spray, if you do (its usually a fine mist so its hard to see, but you will feel it) the spout is bad, replace it.
Jul 27, 2014 | Belle Foret Kitchen Kitchen Faucet With...
Leaking pull out spout
Usually, it is caused by a worn out o-ring.
Jan 31, 2014 | Danze D403412 Melrose Single Handle...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I have a Koiler A112.181M or 157-076-ST kitchen faucet. On the back there is a small hole and it is leaking.. What can I do to stop the leak( A small drip) Thank You Jeff
If there is a hole on the spout itself then you should go ahead and replace th.e whole faucet. This will save you both time and money in the long run
Sep 08, 2010 | Kohler Model 10433: Fort® Single-control...
I've installed a newly purchased Kohler forte 10433-VS faucet but unable to get spray to fully engaged and seems to leave the partial spout running resulting in a in between or partial spray and spout. Is...
Sounds like the diverter is not working properly. It is located in the spout and it maybe sticking or bad. Go to link below for a installation guide with parts break down. Click on installer's and designer's bar below picture of faucet for a diagram of faucet that may help you out.
http://www.us.kohler.com/onlinecatalog/detail.jsp?from=thumb&frm=&module=Faucet+Collection+Kitchen&item=9559802&prod_num=10433&section=1&category=4&resultPage=0-711729362
May 31, 2010 | Kohler Model 10433: Fort® Single-control...
My faucet is leaking from the pulldown where the hose is conected to the spout ive tried to take it apart is there a special way to take it apart
before you take it apart ,I want you to check,the pullout handle first,because most of the time ,all that is wrong is that little1/2-5/8 in washer between the handle and the hose,It usually runs down the hose ,and might apear to be something else leaking under the sink.If your correct,and it is leaking where you said.Some of the newer faucet have a clip that just pushes together.So you need it fing the clip,and push it in.
Apr 12, 2010 | Price Pfister Ashfield Single Control...
Faucet leaks at base of spray handle when water is turned on. How can I fix this leak?
most of the the pullout sprayers need a rubber washer were it meets the hose chek for cracks and replace.
Oct 31, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
I have a Hansa pullout kitch faucet that leaks out of a hole in the back when faucet is shut. Is this a bad backflow preventor and how do I fix it? I can't get the spout off to access the body of the...
I can't get the spout off to access the body of the faucet.
I have the same problem. Have you had any luck?
Sep 05, 2009 | Hansa Home
Kohler K-15160-7 Coralais single-control pullout spray kitchen sink faucet Logo
294 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
