1990 Ford F350 Logo
r
roger hiott jr Posted on Jun 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What could make a 1990 5.0 lose fire - 1990 Ford F350
_-__-___-_
Level 3:
  • Ford Master 20,706 Answers
  • Posted on Jun 30, 2014
_-__-___-_
Ford Master
Level 3:
Answers
20706
Questions
Helped
6796736
Points
57965
You meant lost spark right?
to make fire, it takes 3 things
compression, spark and fuel (and air)
lost spark on all cylinders is the test not one.
if lost on all cylinders, check fuses FIRST.
1990 is a very old car. 5L
the Ford has flash codes, try to get those while cranking.
back then the ECU is near intractable, (sux)
all you get on that year is flash codes.
enable diagnostic mode
crank for 5 seconds,
release the key
see DTC flash codes of why it fails.
every do that?
the Diagnostic conn. has an STI pin, we ground that to do the tests.
this book covers all tests you can do with EEC-IV
http://www.amazon.com/gp/search?index=books&linkCode=qs&keywords=9781133715252
a scan tool can be had (hard work) because if this little secret.
Live data, streaming,
started in 1989 all calif FORD cars.
and all FED cars in 1991 (ford)
this fact explans all the arguments on line, for this odd fact.
the fact is the early FED EEC-IV can NOT data stream.
the above book covers this.
I hop this helps you learn FORD, early OBD1 and to find the bad spark.
desertracer
Level 3:
Master:
  • Ford Master 450 Answers
desertracer
Ford Master
Level 3:
Master:
Answers
450
Questions
0
Helped
91595
Points
1196
Most likely the IGN Module in the Distributer.. it is the thing that the wires are attached to under the distributer, usually gray in color.. could be the coil, could be not getting a 12v single from the ign switch to the coil.
1helpful
My 1990 trooper izusu all of a sudden started losing speed one of the spark plug wires was completely burned before i changed them the trooper is still losing speed why please help
I had the same thing happen to my trooper it started losing power I had to cut out the cateyletic converter and when I did it ran perfect but it was very loud but I only drove it to Darryl's Mufflers he put a new one on she ran like a champ it started to plug up or it could be the timing belt slipped a little, jumped a tooth it would still run depends on how many teeth that it jumped the more teeth it jumps the more it will loose power fast and eventually start missing and back firing and start being hard to start or it jumps to far out of time it will not start at all it will just turn over. If it breaks it will turn over fast and not fire at all. Hope this solves your problem its 2 problems that I know will make your trooper lose power and speed if this does not sound like the problem then call Affordable Battery & Auto Care and ask for Jed let him know Jeff referred you to him and he will look it up and help you diagnosis your problem. Call 503-477-9631 he is really good and he is affordable.
1helpful
Firing order ford 300 six and #1 position on distributer cap 1990
THE 300 4.9 ENGINE FIRING ORDER IS 1 5 3 6 2 4 THE NUMBER 1 POSITION ON DISTRIBUTOR CAP IS AT 6 OCLOCK POSITION.
9helpful
2answers
What's the firing order for a 1990 Mitsubishi Mighty Max (4.banger)?
1990 Mitsubishi Truck Mighty Max 2WD 2.4L FI 4cyl
The Firing Order mitsutrk01:
Firing order 1-3-4-2 --------- front | | of | 1 2 3 4 | Distributor rotates clockwise vehicle | | ---------
1990 Mitsubishi Truck Mighty Max 4WD 3.0L FI 6cyl
The Firing Order mitsutrk04:
Firing order 1-2-3-4-5-6 ------- front | 1 3 5 | of | | distributor rotates counter vehicle | 2 4 6 | clockwise -------
Hope help with this (remember rated this help).
My fuel is not getting into the fuel regulator.but the fuel pump has fire
if youre pump is running and you have no pressure i would remave pump from tank and replace the rubber line between the pump and metal,plastic line the hose gets a small crack and loses pressure back into the tank
Runs ok for 10 min then no inj pulse 2.5 engine this ditributor has no wires going to pick up coil is thi normal
I'm thinking the crank angle sensor is going out. I'd bet when you get no injector pulse, you loose fire too. that would tell me your crank angle sensor is gone.
1992 buick lesabre firing problems
Remave the battery cables from the battery and clean the connections and replace bolts. Have seen this before.
2answers
Honda Accord- no fire
I replaced the main relay assembly.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
