Question about Haier BC112G Wine Cooler
HVTB18DABB lower zone doesn't cool below room temperature.
Under Haier warranty, I've sent the following items back on 05/28/09 in order to receive a replacement unit:
1. 8+ inch section of power cord cut from original unit
2. Serial Number label from rear panel
3. Copy of receipt.
4. Check for $14.99 to cover shipping costs.
Haier has processed the above items on 6/05/09. I made 4 follow up calls and have been informed that HVTB18DABB is back ordered and that my replacement should be shipped soon. I was informed on 6/27/09 that the replacement wine cellar will have a touch screen instead of the 4 push buttons. I am currently awaiting for reported ship date of newer model.
  • Haier Master
  • 3,361 Answers
Next time around do not buy Haier.
Posted on Jun 30, 2009
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
Wine fridge is always running but never cools below room temperature.
the processor cooling fans for the CPU and case fans are 3 PINS.. you can use them but remember that these are 12V fans. once its the same power it will work. Ps if needed you can cut the connects from your old fan and connect it to the new ones to get it to fit properly..
Dec 30, 2012 | Haier HVTS18DBVS 18 Bottle Dual Zone Wine...
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
My air conditioning united seems to be blowing cold air, but its not cooling down my room? Plus the temperature reading never lowers. Thank you in advance.
Sounds like the rear coil may be stopped up with dirt, etc. If it is, the unit will not cool properly. You may just be able to unplug it and wash it out with a hose and sprayer from the back of the unit. If its real dirty, you will have to pull the unit out of the window, take the case off and clean it real good. If you wash it out from the back, be sure you can do it when you can leave the unit off for an hour to dry. Let me know if I can help you any more of if this doesn't work. Stay cool. mark
Jul 10, 2011 | Haier HWR05XC7 Wall/Window Air Conditioner
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Lost Remote
go here: http://www.partlinx.com/haier.asp
andsearch for the part. You have to start with your state, and then gofrom there. For my area, the remote is 19.99, plus shipping and tax.Also, try eBay. You can find a lot of things there!
Aug 24, 2008 | Haier hwr10xc6 Air Conditioner
Haier Wine Cooler won't cycle on and off automatically
If all you are doing is messing with that relay and then it hits the right temp, change the relay. I think the failure is a coincidence.
Dec 21, 2007 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
461 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
