My Kenmore washing machine had a faint burning smell.
I have a Kenmore washing machine, and earlier I was trying to wash a fairly large pillow. Once the pillow became wet and the machine was in the spin cycle, it started banging around and spinning real fast back and forth because it was too heavy. After I heard and ended it, I opened it up and could smell a faint burning scent, like plastic burning or something. Is this something I should be concerned about, or am I just being too paranoid?
  • 530 Answers
I would let it sit for an hour. more than likley what happened was the motor overheated a little because it was trying to spin in an off balance situation. give it a break for a while the next load that you do keep an eye on it and see if you smell anything if you do then you have a problem. But 99% it is ok.
Posted on Jun 28, 2009
Lg tromm front loader moves during spin cycle
Suggests the feet aren't all touching the floor at once, or the floor is particularly bouncy.
Incidentally, if you're washing a large item, such as a pillow, ensure that you wash two at once.
Mar 14, 2015 | Washing Machines
Lg front load washer vibration
are you washing large pillow and bedsheet? any large material that hold great deal of water will cause the tumbler to wobble out of center rotation that in turn causes vibration. stop the machine and get as much water wrung out from the large bedsheet or pillow.i get this problem when my wife wash pillow and large bedsheet. the whole house shake violently if you live in two story home.
Mar 03, 2015 | LG Washing Machines
I just washed this morning and may have put alot of clothes in. Everything went through and when wife put in next load. it only filled up with water. and wont start...actually had a faint burned smell. ...
Probably not the main motor. That is a good thing. If you take the bottom panel off under the door, there is a technicians notes package and that has all the tests that you can run. IT will tell you what the problem is.
Aug 31, 2013 | Kenmore Washing Machines
Kenmore washer in need of repair
sounds like your motor coupling or your lid switch
Mar 08, 2010 | Washing Machines
WASHER STARTS MAKING LOUD NOISES WHEN SPINNING SOUNDS LIKE IT IS OFF BALANCE BUT NOT. ALSO FAINT SMELL OF BURNT RUBBER.
The washing machine will do this if the load is unbalanced. Usually due to either an excessively heavy and/or large load. The burning rubber smell is just the drive belt dealing with the imbalance. Often the washing machine will self-balance itself, but it's a good idea to open the lid and re-distribute the load. Or remove some stuff if it seems too heavy.
Sep 06, 2008 | Maytag Washing Machines
Kenmore direct drive washer - not spinning
While it could be the tranmission, that is a fairly rugged part (although not impossible). More often, you have bad contacts in your timer. These will short together and cause the machine to try and do multiple things at once, thus causing the burning smell. You didn't list a model number, but for most of the Kenmore washers, you can open the console (two phiilips screws on the front or back towards the bottom) to access the timer. Most timers are able to be opened to verify visably black or silver marks on the normally brass colored contacts.
Jun 18, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine stopped midcycle
It seems like the engine of the washing machine has burned out. If you are still in your warrenty period (and you used the machine conform operating instructions) you can contact the store you bought it from and ask for a replacement or repair. Otherwise you'll have to ask a repair man to come but these can be quite expensive.
Aug 08, 2007 | Maytag Performa PAV2200
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
