Question about Sony PlayStation Portable (PSP) Console
Cant find the memory stick duo in
When my PSP connect into my computer! and open the removal disk to my computer!, there is no file in my memory stick duo!, and also my MEmory stick size is 4(GB) but in my computer it becomes 145(MB)!
heLP Me! to recover my PsP Problem!
    Sergeant:
  • 321 Answers
Lol well dude make sure it has nothing on it... go to format memory card in system settings option in the psp
Posted on Jun 28, 2009
How to download in psp games
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 18, 2011 | Sony PlayStation Portable (PSP) Slim...
How to download from the computer to psp?
3. EXIT USB MODE
Apr 12, 2011 | Sony PlayStation Portable (PSP) Console
My PSP memory stick got virused. the problem is my psp cant read my memory stick, then i tried it to my computer but sadly it cannot be read as well but the removable disk [d] is there but cannot be open....
hi..
as you put in your computer the drive is getting detected so you can format it and it wil be fine. But formatting wil erase all your content in it and even the virus.
for formatting follow the steps
1.right click the drive
2.you wil have a option called as format
3.click on it.
4.click quick format
5.format complete wil come
after this this will work properly.
Jul 13, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Unusable memory
When you reformat a memory stick it creates a trash folder which stores all the data incase you need to use it again. Put your memory stick in your psp then connect your psp via usb to a computer, in the computer view of the momory stick make sure you have the 'view hidden folders' option checked, then delete all folders & files on the stick. Remove the psp from the computer & reformat it again you should find 8gb available again
Jun 01, 2009 | SanDisk Memory Stick PRO Duo for...
My psp cant read memory card
I suggest buying a new memory stick but i dont really suggest the 8gb because it crashes
or try removing the memory stick and putting it back again.
May 21, 2009 | Sony PlayStation Portable (PSP) Console
Our computer cant access our psp memory card
fe4875a.jpg Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} PSP uses Sony Memory Stick Pro Duo and you need an adaptor (see picture) to use it on your external card reader or your laptop’s built-in card reader. Also, please check your card reader if it supports Memory Stick Pro Duo.
If you already have an adaptor but still doesn’t work, you can buy a PSP USB data cable to transfer files between your computer and PSP.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp problem
The psp memory stick comes with an adapter, which is where u need to put the memory stick into before trying to place it into a card reader. once you have done that it will appear as a removable disk in my computer. you will then have to open that folder and there is where u can view ur files.
please rate me. thank you.
Dec 02, 2008 | Sony PlayStation Portable (PSP) Slim...
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
