Question about Reebok Vista Treadmill - RBTL13305
Nordic Track Exp 2000 Tmill - do I need a new motor controller?
Out of the blue the other day my 10 year old Nordic Track Exp 2000 Model NTTL11991 treadmill stopped wkg. The lights go on (computer console is ok), but the motor won't run. I removed the motor cover and the lights on one of the circuit boards all seem to go on fine when I try to start up the t mill, but I hear 6 clicking sounds from the motor and then nothing. The computer thinks everything is ok and starts to tally the mileage, etc....but the motor doesn't run.
I attached my cordless drill battery to the motor and it runs fine. So, how do I ck the motor controller to see if that's the culprit? I have a multi meter, but I'm not sure where to attach it to the controller board (not experienced with electronics at all). The other question I have is how do get that darn fuse out to ck it? I don't want to break the plastic fuse casing and I've spent a good 1/2 hr trying to get it off already. I'm told I should definitely ck the fuse first.
Any help would be greatly appreciated.
Thanks,
Dan
SOURCE: help, my Reebok 8700 ES treadmill won't work...
I had the same problem happen today!! I called 188-999-3756, they are sending my a new panel for 5.95! Yes, I bet that many owners of this treadmill have had the same thing happen. Mine is only 8 months old! let me know if you get this message.
Posted on Mar 26, 2009
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
  • 40 Answers
SOURCE: speed fluctuates randomly
Try calibrating the console. If it doesn't work, you'll need a new motor control board.
Posted on Nov 01, 2009
I have a Nordic track EXP 1000 the only keys that work are the start button and 1 mph. Other than that nothing else works. Not sure if it is the controller or the council. Any suggestions?
I had the problem years ago and I contacted NorcTrack and their solution was to replace the entire console for about $400. They wouldn't replace the pads or anything else, all they would do is sell me the new console. That was not going to happen since I had only had the thing for about 5 years at the time. I wasn't going to be putting that kind of money into that treadmill every 5 years or so.
I tried many things and I finally decided to buy a new console pad from the Treadmill Doctor. I think it was around $100. It was easy to replace. I just removed the screws holding the console cover in place, unplugged the wires leading to the lower console pad and pulled it off. The new pad fit exactly into the space the old pad occupied, I plugged it in and it worked. It's still working about 6 years later. I use this treadmill daily without any problems. It's not anywhere near as nice as the new units I see out there today, but it does what it's supposed to do and that's all I need.
The Treadmill Doctor has all the parts you need for this machine at a reasonable price. Much cheaper than Nordic Track.
Mar 15, 2014 | Nordic Track Nordictrack Exp 1000...
My nordic track 2000 lights come on but will not respond when pushing the buttons
adjust the reed switch, clean it , test for open or faulty, tight the connector very well, see the diagram attached, Replace batteries too
Jan 09, 2013 | Nordic Track Nordictrack Exp 2000...
Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
What can be the problem when motor does not start for nordic track model # NTTL9912.0
assuming there is power going to the motor. loose pwer connection or burnt out motor
Mar 06, 2011 | Nordic Track Nordictrack Exp 1000...
My exp 1000 sudenly stops , the counters reset to 0 all the lights are on but the control pannel is nonresponsive an error code 07 showed up once. Any ideas?
I don't have any suggestions for fixing it but I wanted to give you a resource should you need to purchase a new motor control board, you can choose your specific model and browse parts list here. Hopefully you can get it to work though, depending on the model it looks like a replacement can run you $100-$200.
Feb 21, 2011 | Nordic Track Nordictrack Exp 1000...
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Aug 01, 2010 | Nordic Track Nordictrack Exp 1000...
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Reebok Vista Treadmill - RBTL13305 Logo
552 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
