Question about Sharp UX 355L Plain Paper Thermal transfer Fax
Entering my own phone number to a fax machine
I just got a fax machine from a friend and i was wanting to send a fax but it won't go through... the receiptant i was sending it to said that when i cancelled the transcation it should say my phone number on the sheet and it doesn't it says tthe person that owned it... i was just wondering how to change it to where it's my phone number instead so the fax will send
    President:
  • Sharp Master
  • 1,447 Answers
Press help key then print your setting phone no or change
Posted on Jun 28, 2009
HOW TO FAX
  1. Make sure the fax machine is plugged into a power source and also plugged into a working phone jack.
  2. Turn the fax machine on.
  3. Obtain the fax number of the destination fax machine.
  4. Gather the documents you want to send and put them in the order you want them to be received.
  5. Fill out a separate piece of paper called a coversheet with the recipient's name, fax number/phone number, your name, your phone number, a short message and number of pages (including coversheet).
  6. Lay the documents face-up in the fax machine feeder tray with the coversheet on top
  7. Dial the recipient's fax number - put 9 before the number and area code
  8. Press the "fax" or "send" button, depending on the particular fax machine model
Nov 17, 2014 | Office Equipment & Supplies
Lexmark X4270 won't send out a fax
If you have DSL. you need a filter on the line you are trying to fax through.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2012 | Lexmark X4270 All-In-One InkJet Printer
How to use fax machine
You have to connect it to a phoneline that has a fax subscription from a phone service provider. Then you feed it with the paper you want to send, enter the phone number and press send.
Jun 06, 2011 | Office Equipment & Supplies
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I need the instruction to set the machine right for sending a fax from Cambodia to Australia or receiving a fax from Australia. I typed number in Australis to send a fax but my friend there did not receive...
There is not much to do than to set the machine in the fax mode after setting up the time and data as instructed on the interactive menu .
You need to type the STD code of cambodia and the number of the fax there which must also be active. Make sure that you enter the correct local code if the number is in sub-district.
Ask your friend to send the fax after placing your machine in fax mode.
Make sure there is dial tone and you are able to make calls using the telephone mode.
if not check the connection.
Feb 15, 2011 | Brother MFC-7340 All-In-One Laser Printer
How to fax from a samsung fax machine
hi friend,
Step 1Create a cover letter to use saying who the document is for and from as well as the intended fax number and your phone number. This alerts the office or home the fax is sent to who it is intended for. Place cover letter on top of your documents and insert them into the fax machine feeder facing in the direction the machine specifies.
  • Step 2Enter the fax number into the machine. There will be a number pad just like a phone on the fax machine. Carefully type in the number so you do not make any mistakes, as it is difficult to know when you have dialed a wrong fax number.
  • Step 3Hit the send key once you have properly entered all of the numbers into the machine. This will initiate the sending of the documents. The send key should be larger than the others and easy to locate. Traditionally, it is placed next to or below the keypad.
  • Step 4Wait for your documents to pass through the machine and collect them when finished. Whatever you are sending will pass through a series of rollers that feed it through the machine and copy it digitally.
  • Step 5Look for a confirmation page to print. This will tell you whether or not your fax successfully went through.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); })hope this helps u
    please rate me....................
    thak u for using fixya
    regardsa
    sivaranjini
    Dec 01, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
    Unable to enter faxes while the machine is either sending or rece
    turn off
    Real Time Transmission
    When you are sending a fax, the machine will scan originals into memory before
    sending. Then, as soon as the phone line is free, the machine will start dialing and
    sending the fax. If memory becomes full, the machine will send the document in real
    time (even if REAL TIME TX is set to OFF).
    Sometimes you may want to send an important document immediately, without
    waiting for memory transmission. You can set REAL TIME TX to ON.
    1 Place the original face down in the ADF.
    2 Press Menu, 2, 2, 6.
    3 To change the default setting, and then
    press or to select ON (or OFF) and
    then press Set. Go to Step 5—OR—For
    the next fax transmission only, press or to select NEXT FAX ONLY,
    and then press Set.
    4 For the next fax only, press or to select ON (or OFF), and then press Set.
    5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
    menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
    6 Enter fax number and then press Fax Start.
    May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
    My friend wants to send me a document by fax and i have only 10 digits fax number , she asked me to send a complete number that is required to send fax to usa i.e. i guess US country code. how she should...
    US PHONE NUMBERS HAVE 9 NUMBER WHERE INTERNATION RANGE 9-12 NUMBER,JUST ENTER THE NUMBERS WITHOUT THE SPACES OR DASHS
    OUT SIDE OF YOUR STATE NEED TO ADD A 1 AT THE BEGINNING
    CANDYMANGANDY
    CANDYMANGANDY
    Jan 28, 2009 | Office Equipment & Supplies
    I need to send a mass fax once a week
    you need to program the numbers you want to fax in the speed dials and abbr numbers, then you can use a program key to select them all.
    function-7-2-start [this is where you program your numbers]
    function-7-3-start-1-start- then push your p key enter a name then hit start then select your phone numbers
    Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
    Won't send faxes
    did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
    If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
    The FAX Mode is the setting for incoming faxes.
    Try that and let me know if it works.
    There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
    Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
    Once you hear the fax high pitch noise, hit the start button.
    Hope this helps.
    Let me know if it does and also remember to leave a feedback and rating if I have helped you.
    Thanks and good luck.
    Mac =)
    Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
    Open Questions:
    Sharp UX 355L Plain Paper Thermal transfer Fax Logo
    112 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
